Coilovers catching on arch
Old Nov 30, 2013 | 09:08 AM
adam151082's Avatar
adam151082
Default Coilovers catching on arch
Hi everyone. Im wanting to go back to coilovers on my car but the last set I had used to catch on the passanger rear arch, is there anyway round this or does anyone make a set that dont catch
thanks
Old Nov 30, 2013 | 09:20 AM
cos 4x4's Avatar
cos 4x4
From what I've read they all do that so you have to fettle the inner arch a bit
Old Nov 30, 2013 | 12:48 PM
charlie luciano's Avatar
charlie luciano
Very annoying rubbing sound that does your nut it as said you have to modify the inner arch a bit usually with a hammer
Luciano
Old Nov 30, 2013 | 01:00 PM
adam151082's Avatar
adam151082
Would it be possible to move the mounting point on the bottom arm or would that totally ruin the handling?
Old Nov 30, 2013 | 01:07 PM
Staffi's Avatar
Staffi
I wouldn't even use them on a road car full stop, horrid things.
But to answer your question Adam, quite a few seem to catch from what I've heard, how you solve it i don't know so I'm pretty useless really aren't i ?
Old Nov 30, 2013 | 07:48 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
some do, some dont its all down to tollerances when all the pannels are spot welded together!
i ususally solve it by moving the base of the coilover right out towards the outer side of the mount and make an offset spacer for the rosejoint.
but i only use 909 Tarmac stuff, might help you, might not lol
Old Nov 30, 2013 | 07:57 PM
D16PJM's Avatar
D16PJM
It's Hammer time
Old Nov 30, 2013 | 11:15 PM
Ade's Avatar
Ade
Fast Ford snapper
Never had any problems with stuff catching with my Gaz Golds or AVOs on my previous car.
To be honest I wouldn't want to go back to a regular setup.
Coilovers are what you make of them.... adjustment is the key!
Old Dec 1, 2013 | 09:15 AM
xr_craig's Avatar
xr_craig
Space it out as Sean said and if it still catches get the hammer out
Old Dec 1, 2013 | 09:23 AM
KSA-Cossie's Avatar
KSA-Cossie
Me neither Ade, I find my set up better than my old koni/Ahmed
Old Dec 1, 2013 | 12:11 PM
Paul_RS's Avatar
Paul_RS
Drive a car with decent ones and you'll soon change you mind
mk1turboestate
Dec 2, 2015 08:31 PM
Nov 1, 2015 06:53 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
benw456
Sep 16, 2015 05:27 PM
