Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Fitting st side skirts to a standard fiesta
Old Nov 26, 2013 | 02:12 PM
Connorhood1's Avatar
Connorhood1
Default Fitting st side skirts to a standard fiesta
Do they just fit on and Will it be just like fitting the spoiler? Bit of tiger seal on them and then propped up
Old Nov 26, 2013 | 02:15 PM
Connorhood1
These will be getting fitted from a mk6 st to a mk6 zetec
Old Nov 26, 2013 | 03:10 PM
James B's Avatar
James B
I would have thought so mate, dunno if being 3/5dr makes a difference but assuming you mean a 3dr I'd have thought they would. I'm sure someone can be certain tho
Old Nov 26, 2013 | 09:11 PM
RSmark84's Avatar
RSmark84
When i looked at a MK6 ST the sill had lots of square holes stamped into them. Then the side skirt had lots of brackets with square clips in them. These popped into the sill which held the skirt on. They seem to pop quite easily.
If you are fitting the skirts expect to drill holes and file them out into squares and trial fit the skirts until they fit flush.
Old Nov 26, 2013 | 09:50 PM
:hEnNiKeR:'s Avatar
:hEnNiKeR:
Bam Bam Bam
I did this to mine about 5 years ago.
As far as i remember it was pretty straight forward with NO drilling holes.
Should be self explanatory with the skirts and car in front of you, i dont remember it being a big deal. Improves the looks 10 fold though
manuel boeckx
13
Oct 3, 2015 02:29 PM
M K
Aug 12, 2015 06:57 PM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
