under body hose clamps
So ive got a 5mm O.D brake line, an 8mm O.D Fuel return, and a 14mm O.D fuel feed to run under the car, whats the neatest way to do it? Ive seen the aluminium hose separators on ebay but they are the same size both sides and only hold two pipes.
On the old car the fuel return and brake line were in the standard clips with the aeroquiped fuel feed run along side held up with cable ties.
My only thoight at the moment is to use them hose separators but wrap the fuel return in electrical tape until the clamps hold it tight, then P clip the brake line along side.
I want to put as few holes in the floor as possible, I was thinking of using rivnuts to hold whatever clamps.
Any ideas?
Any ideas?
