T5 clutch arm pivot
Old Nov 3, 2013 | 01:38 PM
fraser9764's Avatar
fraser9764
Default T5 clutch arm pivot
What do they look like normally? And where can I get one? Mine is missing
IIRC they are a small block that bolts into the bellhousing? Clutch has felt odd for a while and now ive got the box out the arm is just sat against the bellhousing with nothing to hold it or for it to pivot on.
Old Nov 3, 2013 | 02:02 PM
costina's Avatar
costina
Live long and prosper!!
You can't get them. Just drill and tap a M6 thread and fit a cap head bolt (not fully in as the arm needs to sit under the head of bolt)The clutch arm hooks inside and then pivots on that Loctite it into position once your happy its works ok.
Regards
Paul
Old Nov 3, 2013 | 02:03 PM
costina's Avatar
costina
Don't forget a dollop of grease too
Old Nov 3, 2013 | 05:13 PM
fraser9764's Avatar
fraser9764
Nice one cheers, nice and easy solution.
another job to do while making up the mounts for the hyd clutch.
Old Nov 3, 2013 | 09:05 PM
Ridgey's Avatar
Ridgey
How's it going graham?
I'll give you a bell this week.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
