Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Mk4 fiesta brake set up
Old Nov 2, 2013 | 05:02 PM
Pockets2012's Avatar
Pockets2012
Default Mk4 fiesta brake set up
Can any one give me some ideas on a good set up but can still fit most alloys I'm after rear disc too
Also witch is the best route for rear disc as I have no abs
Thanks
Old Nov 2, 2013 | 05:29 PM
gjh's Avatar
gjh
What size alloys are you running??
You can get a 4pot caliper with 285mm disc under most 15s, think 300mm under most 16s, possibly 355mm under 17s (not 100% sure here), wouldn't want to run a larger wheel than that on a fiesta, as for rear discs, think 2.0 focus stuff fits.
Old Nov 2, 2013 | 05:36 PM
Mk4 Rick's Avatar
Mk4 Rick
Ive got 300mm Mondeo calipers behind 16 inch wheels.They will go behind some 15s but the caliper will need trimming down
Old Nov 2, 2013 | 05:39 PM
Pockets2012
Either 15 or 16 alloys
I see puma build got conversion for rear but can't find a number and were can I find 300mm fronts ??
I seen people with cossie fonts ??
Old Nov 2, 2013 | 05:41 PM
Pockets2012
What caliper you using its in a straight fit do I need to change hub ??
Old Nov 2, 2013 | 05:47 PM
Mk4 Rick's Avatar
Mk4 Rick
Caliper fits straight to the hub.Just got to drill the hub holes out and space the carriers out a bit.Its a good set up.Also depends on what you want to spend as well if you want looks or purpose.Ive also got the mk2 mondeo servo fitted as well
Old Nov 2, 2013 | 05:58 PM
Pockets2012
Purpose ill just paint lol I've got a mk2 mondeo servo lol
So would I be able to fit fiesta marster cylinder ??
Tell me what calipers I need and witch disc as where can I get them from ??
Please
Old Nov 2, 2013 | 06:18 PM
Pockets2012
eBay number 271300077464 is this what I could use ??
Old Nov 2, 2013 | 06:29 PM
Mk4 Rick's Avatar
Mk4 Rick
Please
Mk2 servo will fit straight on if non abs model.If its the abs model you will have to adjust the brake lines to suit.Mk3 mondeo calipers and st170 300mm discs job done.Fit braided lines if you want for a firmer brake pedal and if you want to go mad use blue brake fluid but its expensive
Old Nov 2, 2013 | 06:30 PM
Mk4 Rick's Avatar
Mk4 Rick
couldn't advise to be honest never tried it
Old Nov 2, 2013 | 06:34 PM
Pockets2012
Could I put the fiesta marster cylinder on mk2 mondeo servo as the servo had abs master cylinder but its off atm
Old Nov 2, 2013 | 06:43 PM
Pockets2012
Sorry just to make sure these one
231074572734 ??
With these
320721530278
eBay agin sorry
Thanks for the help
Old Nov 2, 2013 | 06:55 PM
Mk4 Rick's Avatar
Mk4 Rick
Bolt holes wont line up I thought of that a while back
Old Nov 2, 2013 | 06:58 PM
Mk4 Rick's Avatar
Mk4 Rick
231074572734 ??
With these
320721530278
eBay agin sorry
Thanks for the help
yes perfect just make sure them pads are for the mk3 mondeo and the discs are defo st170 discs
Old Nov 2, 2013 | 07:28 PM
Pockets2012
Shame can I get a mk2 non abs to fit as the cylinder was new from 2011 lol
Old Nov 2, 2013 | 07:29 PM
Pockets2012
Right so mk3 mondy calipers with pad and st170 discs how much spacing will it need
And how about the rear disc ??
Old Nov 2, 2013 | 07:31 PM
Pockets2012
Any way of adapting the fiesta one like cutting and welding ?? Make one side longer
Old Nov 2, 2013 | 07:32 PM
Mk4 Rick's Avatar
Mk4 Rick
yeah sure you can
Old Nov 2, 2013 | 07:33 PM
Mk4 Rick's Avatar
Mk4 Rick
Its only a few mm get some penny washers
Old Nov 2, 2013 | 07:46 PM
Pockets2012
Bend it lol
Old Nov 2, 2013 | 07:48 PM
Pockets2012
Do you have any idea on rear disc ??
Old Nov 2, 2013 | 08:00 PM
Mk4 Rick's Avatar
Mk4 Rick
Think most go for a focus rear set up
Old Nov 2, 2013 | 08:06 PM
Pockets2012
Have you still got drum then ??
Old Nov 2, 2013 | 08:33 PM
Mk4 Rick's Avatar
Mk4 Rick
yeah and im running a 2 litre blacktop
Old Nov 2, 2013 | 08:42 PM
Pockets2012
But will drum be upto the job for 400 bhp that's what I'm after I've got a 2.0 silver top witch I thought was black top but didn't know that silver was alloy rocker lol bummer but still get what I need
Old Nov 2, 2013 | 08:43 PM
Pockets2012
What and where did you get your drive shafts ??
Old Nov 2, 2013 | 11:32 PM
Mk4 Rick's Avatar
Mk4 Rick
Drums will be more than ample
Old Nov 2, 2013 | 11:33 PM
Mk4 Rick's Avatar
Mk4 Rick
Im still using 1.2 drive shafts
Old Nov 3, 2013 | 12:39 AM
Pockets2012
How much bhp you running also how you get the to fit ??
Old Nov 3, 2013 | 06:51 AM
Pockets2012
http://www.fastfordmag.co.uk/files/old/FAF244.tool.pdf
I found this I see there is some work but will look a lot better
Old Nov 3, 2013 | 12:25 PM
Mk4 Rick's Avatar
Mk4 Rick
Im running about 140bhp.Its quick and doesn't hang about.The drive shafts are a direct fit im using the diesel ib5 gearbox not an mtx75.I do have a turbo plan at a later date.ive had some minor issues to sort out with the fiesta that needed seeing to first
Old Nov 3, 2013 | 04:04 PM
Pockets2012
Ahh I see I want to keep the mtx as it be ok wen I go to 400 Im gonna weight a list soon on my engine rebuild now I got me brake list witch I'm gonna buy all before xmass and start on engine after lol I wana get drive shafts first the engine
Old Nov 3, 2013 | 04:43 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
I assume you've factored in the work chopping about to fit an mtx?
The 300mm set up is very good, some people don't like taking a grinder to the caliper but it's fine. Go up to 16's and you can go with something like 406/Fiat Coupe Brembos.
Old Nov 3, 2013 | 06:24 PM
Pockets2012
BRenbo will be nice lol I wana go 16 as I won't have to lower it
Old Nov 3, 2013 | 06:26 PM
Pockets2012
I didn't think I had to but summit told me I would lol unless u know of any gearbox that could take 400bhp with out to much changing
Old Nov 3, 2013 | 06:35 PM
Straight_4_N/a's Avatar
Straight_4_N/a
focus mk1 1.8 ib5 have been known to run that power and will near enough bolt straight into the car iirc the torque links a bit of and will bolt straight to the engine
Old Nov 3, 2013 | 06:40 PM
Pockets2012
What about the shafts ??
So the focus 1.8 fits is it cable ??
So what will I need for it to fit ??
Old Nov 3, 2013 | 06:54 PM
Straight_4_N/a
same fitment as a se fiesta.
yeah its simple to drill a hole and just bolt the new gear shifter in place.
Just fit the fiesta upper mount on the top of the focus is and it will bolt straight in, as for the torque link I'm not 100% as I ddidn't help my mate modded his but I know it wasn't a direct fit, and he used an aftaftermarket vibe one iirc he either bent the vide bar to the right angle or replaced the bar but it's really not hard to customise a vibe torque link as it's just a metal bar with two bushes welded at each end.
Old Nov 3, 2013 | 06:58 PM
Pockets2012
Mite be summit to consider but I'm a little worries on the little fiesta shafts as 400 is gonna be a lot for them
Old Nov 4, 2013 | 12:26 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
IB5 would poo itself.
MTX is the best way, it's worth the hassle.
