Is this an rs500 block
Old Nov 1, 2013 | 11:44 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Default Is this an rs500 block
Old Nov 1, 2013 | 11:55 AM
Jasu's Avatar
Jasu
Not original, but similar.
Old Nov 1, 2013 | 11:56 AM
opposite lock's Avatar
opposite lock
The core plugs look small which could mean it is one.
Old Nov 1, 2013 | 12:06 PM
ajamesc's Avatar
ajamesc
I'm not bothered if it's original just need a block the big horse power it seems to have small core plugs and I've read some thing about extra web on top alternator bolt?
Old Nov 1, 2013 | 12:18 PM
Jasu's Avatar
Jasu
Ok.
If the block is intact, it will take reasonable power.
Old Nov 1, 2013 | 12:59 PM
ajamesc's Avatar
ajamesc
Ok.
What's reasonable mate I thought they were stronger than 200 blocks? I'm doing 650bhp
Old Nov 1, 2013 | 01:08 PM
martysmartie's Avatar
martysmartie
It should have 'YBD' followed by a code?
Martin
Old Nov 1, 2013 | 01:11 PM
Jasu's Avatar
Jasu
Even stock 200 block can handle easily +700hp.
I do not know that is the basic 200 block more durable than the basic 500 block, or vice versa.
Old Nov 1, 2013 | 01:13 PM
ajamesc's Avatar
ajamesc
Yeah it can with liners in it I may just go the 200 route saves confusion
Old Nov 1, 2013 | 01:15 PM
Alps Pacino's Avatar
Alps Pacino
my gen 500 block cracked all the way down one side between every water jacket and bolt hole at 400bhp
ajamesc's Avatar
ajamesc
Martin
I was under the impression there where also ford made motorsport replacement ones that had no stamps on them? Bit confusing all this lol may stick too a 200 block
Old Nov 1, 2013 | 01:17 PM
ajamesc's Avatar
ajamesc
I guess that's the luck of the draw mate rod used a 500 block as I be leave it's stronger
Jasu's Avatar
Jasu
Even without liners.
Old Nov 1, 2013 | 01:22 PM
Dirty Harry's Avatar
Dirty Harry
Super Moderator
why isn't it original,
Old Nov 1, 2013 | 01:33 PM
Alps Pacino
That's sort of what I was getting at so cost dependant why not just buy a 200 block as I can imagine there a lot cheaper than a gen 500 block?
Why not ask the tuner who is going to be building the motor what they would suggest? Not a dig but through past experience picking someone reputable and using them from start to finish normally saves a lot of time and hassle along with lots of money even if it looks more expensive in the first place
Old Nov 1, 2013 | 01:35 PM
ajamesc's Avatar
ajamesc
I'm using m.a.d just sourcing a block to use plus this one is 500 pounds
X8MRK's Avatar
X8MRK
I thought rs500s used 200 blocks?
Old Nov 1, 2013 | 01:36 PM
ajamesc's Avatar
ajamesc
That all comes down to opinion lol
Old Nov 1, 2013 | 01:39 PM
Alps Pacino
I'd be asking Mark then if this block is good for what you need then you will get a simple straight answer of yes or no rather than a load of bellends arguing over weather its genuine, fake, Turkish, irish or any other bollox
Old Nov 1, 2013 | 01:40 PM
Alps Pacino
no 205 but not the same as a 2wd 205 block
Old Nov 1, 2013 | 01:44 PM
ajamesc's Avatar
ajamesc
I no what your saying bud I can pick through the junk just wanted to know if it is a 500 / motorsport 500 block. I'm in too minds now as this block is on a 94mm bore and the liners I'll be using are just over 94.5 so thinking I may just look for a standard 200 to save messing about
Old Nov 1, 2013 | 05:46 PM
Mark Shead's Avatar
Mark Shead
Rod uses a 4wd 200 block.
Mark
Old Nov 1, 2013 | 05:54 PM
ajamesc's Avatar
ajamesc
Mark
That's what I'm going to do now will be a safer bet than messing about with an un known it was just close by
Old Nov 1, 2013 | 08:20 PM
Mr RS500's Avatar
Mr RS500
That block is a Gen rs500 motorsport block
Old Nov 1, 2013 | 08:23 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
That was on ebay, its honed to fuck and decked for a n/a build.
Old Nov 1, 2013 | 08:27 PM
costina's Avatar
costina
Live long and prosper!!
PM for ya James
Old Nov 1, 2013 | 08:39 PM
ajamesc's Avatar
ajamesc
Says nothing about being decked and is bored to 92.8 but he says there's damage to a bore and it needs boring to 94mm not sure why lol any way the liners I'll be using are just over 94.5 so I may still go look at it
Old Nov 1, 2013 | 08:50 PM
Mark Shead's Avatar
Mark Shead
Deck height will be needed to be checked.It should be over skimmed.
Mark
Old Nov 1, 2013 | 08:51 PM
costina's Avatar
costina
Mark
which is ? top to bottom face?
Old Nov 1, 2013 | 08:54 PM
DixieTheKid
Pick-up P100 Power!
Sorry, i thought the add said it had been decked by quite an amount. May be thinking about two different adds.
I have a 205 block thats been lined, i was advised that the heat transfer between the two materials can create problems. So i used a different block and oversized pistons.
On the other hand i've also been told that reylands Nikasil Liner Conversion is the ultimate thing to have.
Either way its Ideal now as i have a spare bottom end just in case
Mark Shead's Avatar
Mark Shead
I would check it at crank line.
Mark
Old Nov 1, 2013 | 09:01 PM
costina's Avatar
costina
Do you have a stock measurement Mark?
Thanks
Paul
Old Nov 1, 2013 | 09:09 PM
DixieTheKid
Pick-up P100 Power!
Thanks
Paul
Lets make it a quiz.
Complete guess of 205mm hence the 205 block?
Old Nov 1, 2013 | 09:11 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Mark
Selected because it had 25k low powered miles & heat cycled. It was a new Block that cracked.
Old Nov 1, 2013 | 09:18 PM
costina's Avatar
costina
A used block is always best BMW F1 turbo blocks were used items left outside in all weathers and pissed on too apparently
Old Nov 1, 2013 | 09:33 PM
frsjon's Avatar
frsjon
cant say fairer than that
Old Nov 1, 2013 | 09:45 PM
Jasu's Avatar
Jasu
207.5mm is std. height.
Old Nov 1, 2013 | 10:00 PM
costina's Avatar
costina
Thanks Jasu
Old Nov 2, 2013 | 01:33 PM
martysmartie
Wrong, 205 denotes the capacity and the year.
Martin
Old Nov 2, 2013 | 02:14 PM
ajamesc's Avatar
ajamesc
Iver way it's not for me now the guy says it's had 15 thou taken off the deck hight.
Had it not id have brought it and used it.
