Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Mk5 fiesta suspension
Old Oct 28, 2013 | 09:58 PM
leejst's Avatar
leejst
Default Mk5 fiesta suspension
Hi I've just bought a 2000 mk5 1.3 5door and looking to get it lowered would zs shocks and springs fit along with rs2k wheels if so how low could I go?
Thanks lee
Old Oct 29, 2013 | 09:30 PM
pumesta's Avatar
pumesta
Thanks lee
They should fit and lower the car approx 20 mm. However the mk5 Fiesta had two different types of fitting for the rear shocks a fork fitting and eye fitting, you need to make sure you get the correct type. However by the time you buy new ZS springs and shocks you could probably get a set of after market springs and dampers which will lower it 40-60 mm depending on brand
Old Oct 30, 2013 | 07:57 AM
leejst's Avatar
leejst
Thanks for your reply mate I'm probably gona look around and try get aftermarket springs and shocks or maybe coilovers. I was gona get some specific for the 1.3 although I'm thinking of changing the engine next year hence wanting to go for the zetec s suspension. I have the eye fitting on the rear but was unsure if the zs front struts would be a bigger diameter where they fit into the hub with it being 1.3 to begin with?
Nov 1, 2015 06:53 PM
Steve Escos
Oct 1, 2015 06:57 AM
SMILER258
Sep 28, 2015 09:04 AM
