photoshop help
got a problem with photoshop, wheneva i open a photoshop file (with the layers etc that i've been workin on before and go to use the eraser tool it doesnt work, but if i add anything i can eraser it but then if i save it and exit photoshop then reopen it the eraser tool doesnt work
its neva done this before and i'm really stuck, i have just instealled norton firewall 04 on the system but i've used it before and neva had this problem before
anyone help please
anyone help please
You need the correct layer for the part u want to erase.. i.e if uve added a spoiler (layer 2) it will only erase / clone, whatever for that layer.
Just make sure u dont merge the layers, or u'll have to use the clone tool, to blend it in.
hope this makes sense, hope it helps
Steve
Steve
Photoshop uses layers so you can edit induvidual elements of a picture and effecting the other parts of the picture.
Press F7 and you should see this window
This window shows you all the layers in the current project and in what order they are in, top most being at the front, lowest at the back. You can click and drag these about to reorder them. It also shows you what effects have been added to that layer.
In that picture, Layer 5 is highlighted and has a paint brush in the box on the left showing that layer is selected for editing.
If you click the little eye you can hide/unhide layers.
Now I want to erase the toon ecossie from the picture below.
But as layer 5 is selected (in this case the background) it will only erase that and not the cossie
So I have to select the layer 3 (the cossie) and try again;
hey presto, can now erase the cossie.
Hope this helps.
Hope this helps.
nah it wasnt a layer problem the ersaer tool wasnt workin at all on nething that had been saved prior to that session.
but i fixed the problem, when u save a piece of work u have to enable ICC profile, this enables u to edit/delete the colours after u've saved it.
so now everything works fine which is a good job cos i was propa brickin one cos i use photoshop for my work.
ossie cossie
Sep 21, 2015 05:07 PM
