Ford Puma Discuss the Ford Puma here!
Ford Puma with mk3 mondeo front brake calipers
Old Oct 24, 2013 | 03:17 PM
Default Ford Puma with mk3 mondeo front brake calipers
Right people I know these calipers a bit of a tight squeeze under 15inch puma wheels.I know people trim the calipers down with a grinder.So which parts of the caliper need to be trimmed down so they dont catch the inside of the wheels.
I know some people might think this is dodgey but its only a bit that needs to be trimmed off.
So using the pic can someone point out which parts of the caliper need to be trimmed/grinded.
Old Oct 24, 2013 | 03:18 PM
Mods please dont move to the forf puma room cause my question wont get answered in there cause I dont think many people look in there lol.
Old Oct 24, 2013 | 04:01 PM
Maxwell's Avatar
Maxwell
Irregular Poster
Try a wheel on, spin it, see where its catching and remove the excess meat?
Old Oct 24, 2013 | 04:07 PM
2wdsaph ben's Avatar
2wdsaph ben
Pm sent glenn
Old Oct 24, 2013 | 04:54 PM
cos 4x4's Avatar
cos 4x4
The two raised areas on the top and sides need cutting off.
And the top front needs grinding down.
The edges of the carrier need grinding down aswell.
3 mm wheel spacers will be needed.
Have a look on zsoc plenty of info and pics on there about it
Old Oct 24, 2013 | 04:56 PM
I did think of that matey.I just thought I will do the grinding now whilst I have the calipers at work.
Old Oct 24, 2013 | 04:59 PM
Originally Posted by 2wdsaph ben
Pm sent glenn
Havent got it yet.
Old Oct 24, 2013 | 05:00 PM
Right matey I will have a look on there.
Old Oct 24, 2013 | 05:04 PM
Have to be a member to look at the threads on the zsoc site.
Old Oct 24, 2013 | 05:35 PM
bagginsRSturbo's Avatar
bagginsRSturbo
sign up glenn its free unlike some forums
Old Oct 24, 2013 | 07:08 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
There's a guide on PP Glenn.
Old Oct 24, 2013 | 08:49 PM
It doesnt show you how much to grind off though.
Old Oct 24, 2013 | 09:05 PM
dangerousbrian's Avatar
dangerousbrian
have a game of caliper grinding roulette (just invented it in my head). see how much you dare grind away before knacking the caliper. sorry for being an unhelpful nob!
Old Oct 24, 2013 | 09:09 PM
mk1turboestate's Avatar
mk1turboestate
just make sure you use a flap disk so its nice and neat
Old Oct 24, 2013 | 09:23 PM
Just remembered im a member of the zsoc. I still cant see any threads on trimming the calipers down.
Old Oct 24, 2013 | 09:24 PM
Dont worry I will make a good job of it.
Old Oct 24, 2013 | 09:30 PM
cos 4x4's Avatar
cos 4x4
If u haven't got a jig then take a little off at a time and test fit
It's approx 2 mm on the top front and tapers back
The two indents will nearly disappear
Old Oct 24, 2013 | 09:33 PM
dangerousbrian
attempting to be a bit more helpful i came across this page, which has a few pics. hope this helps.http://www.pumapeople.com/forum/inde...0&#entry824981
Old Oct 25, 2013 | 04:24 AM
Im starting to get worried now incase its gonna be a right chew on to get the calipers to fit.
Old Oct 25, 2013 | 08:01 AM
Or loooook where this thread ended up lol.
Old Oct 25, 2013 | 08:11 AM
STeve's Avatar
Super Moderator
glenn I left this thread in general so you got replies first but after all its a puma themed thread so it had to go here, plus you need to get the puma area buzzin again
Old Oct 25, 2013 | 11:15 AM
Ok no bother. I Dont think many people come in this section.
Old Oct 25, 2013 | 11:20 AM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
With the amount of new owners we should be able to get it lively again
Old Oct 25, 2013 | 05:30 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Boom!
Sorry Glenn, there's a picture in PP somewhere but it's not in that guide I only looked at it the other day as well, it was linked off here!
Old Oct 25, 2013 | 05:49 PM
Bought some ST170 discs today.I tried them in my 15inch steel wheel.They look massive.
Old Oct 25, 2013 | 05:51 PM
40 quid.bargain.
Old Oct 25, 2013 | 08:00 PM
dojj's Avatar
dojj
Resident Wrestling Legend
if you have a spare hub mate you can stick the disc and caliper on there rather than having to hoist your motor up in the air time and again when trial fitting
Old Oct 25, 2013 | 08:01 PM
dojj's Avatar
dojj
don't forget you've got to open up the holes to 12mm with a step drill too, a few seconds work if you have the step drill, plus it centres the hole too, don't be pikey about it with a round file
Old Oct 25, 2013 | 08:50 PM
I was hoping to take the car to work tomorrow and trial fit them. I wanna grind the calipers down for the clearance.
Old Oct 26, 2013 | 11:41 AM
T4onYB's Avatar
T4onYB
FRS chap
I just bought a puma too as a fun car, these cars drive great
Old Oct 26, 2013 | 11:42 AM
SBT83's Avatar
SBT83
Pictures matey? Which model you gone for?
Old Oct 27, 2013 | 08:09 PM
Straight_4_N/a's Avatar
Straight_4_N/a
Im so glad i just bought diffrent wheels making it is simple bolt on conversion other than drilling the hubs lol.
Old Oct 27, 2013 | 08:20 PM
dojj's Avatar
dojj
But the wheels don't mean shit, you still have to drill the hubs as one uses 10mm bolts and the other uses 12mm bolts
And without drilling they won't fit, no matter if you could get 20" rims to fit lol
Old Oct 27, 2013 | 08:28 PM
Straight_4_N/a
somebody missed the last 6 words of my post lol.
Old Oct 27, 2013 | 08:45 PM
Eeehhhhhhhh..
Old Oct 27, 2013 | 08:50 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Glenn, its not that hard to do in situ. Dont plumb them in if you want to clean up the callipers after, just bolt the callipers on and trial and error basically, its only a couple of mm off each front edge.
And ps the callipers will NOT fit under steel wheels! Unless you get 16" mondeo ones lol
Old Oct 28, 2013 | 06:13 AM
Have you seen my other thread matey.
Old Oct 28, 2013 | 07:39 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
dunno, probably not!
Old Oct 28, 2013 | 08:19 AM
dojj's Avatar
dojj
Use the same brake lines too as you can't get those little brackets apart or on their own so either buy new lines at £40 a side or use your old ones
