Breaking 2wd saff stage 3 and other parts available
Ford Sierra RS Cosworth
Spec
200 Block
T34 Hybrid Turbo with -34 Actuator ( inspection from doug sport turbos July 2013)
RS 500 Intercooler
3 Bar Map Sensor
Baily oil tank
Baily Coolant Tank
Baily Dump Valve
Alloy Swirl Pot
Alloy Radiator with twin fan and separate control
PJ Motorsport 380BHP Conversion and remap 14/09/05
Group a Bosch Fuel pump 044 Fitted New May 2011
Light Blue 400 Bosch Injectors Rated to 400BHP
Dyno Print out for 350BHP @ 18psi Boost, now running 22psi Safe
4” Full Stainless Scorpion Exhaust System
Morrette Twin Headlights (Have Standard)
Lockwood White Dials
Koni Adjustable Dampers and lowering Springs
17” Khan Alloys with Spare Good tyres allround
Front Suspension Polly Bushed
OMP Stut Brace
hi mate
engine as a long motor is £1750
Engine
Fully Rebuilt in 2007 With all receipts
Group A Cam Belt
Cam Belt Tensioner
Big End Bearings and Main
4WD Oil Pump
Valve Steam Seals
Thrust Washers
ARP Big End Bolts
ARP Con Rod Bolts
4WD Water Pump
Bottom End Seals
Head Bolts
Cometic Rocker and Half Moons
Cometic thick Inlet Gasket
Cometic thick Exhaust Gasket
Group A Head Gasket
Rotor Arm
Dizzy Cap
Motorsport Ignition Leads
4x4 Thermostat
Engineer Work
Re Ring Wire Block To Rebore Cylinders
Check Con Rod Alignment
Machine Pistons To The Required Compression (7:2:1)
4 New Pistons
Flywheel Skimmed and lighted with new doul
Check Crank and Polish
Cylinder Head
Pressure Test Head
Skim Cylinder Head
Cut Valves and Seats
Strip and rebuild head
New parts and recent work
Oil and Filter Changed May 2012 10w/60 Racing oil July 2012
Crank and Phase Sensor set up July 2012
New Ford Motorsport Spark Plugs rated to 700BHP
New Fuel Pressure Regulator and Set up
Engine
Group A Cam Belt
Cam Belt Tensioner
4WD Oil Pump
Valve Steam Seals
Thrust Washers
ARP Big End Bolts
ARP Con Rod Bolts
4WD Water Pump
Bottom End Seals
Head Bolts
Group A Head Gasket
Rotor Arm
Dizzy Cap
4x4 Thermostat
Engineer Work
4 New Pistons
Cylinder Head
Pressure Test Head
Skim Cylinder Head
here are some of the parts
pace intercooler £120 SOLD!!!
airtec rad £110
bailey header tank £85
swirl pot £45 SOLD
breather £55 SOLD
fuel reg £45 SOLD
3 bar map sensor repaired and works perfectly £55
turbo damper (not bailey) £50
light blue 400 injectors £150
strut top nut covers £10
new ap clutch plate £125
revcounter £30
lockwood clocks £45
17 inch khan wheels set of 5 £300
airtec rad £110
swirl pot £45 SOLD
breather £55 SOLD
fuel reg £45 SOLD
revcounter £30
lockwood clocks £45
