Oppliger Motorsport – Impostor?
Old Oct 15, 2013 | 03:17 PM
turbo965's Avatar
turbo965
Default Oppliger Motorsport – Impostor?
At the beginnig oft he year I bought a Coswworth YB N/A Motor, promised 240 – 250 hp and 1000 km mileage, at Oppliger Motorsport.
To the test turned out that the engine made noise and had 206 hp only.
After opening of the engine revealed the following:
Chipped piston on the cylinder head, there by annealed and connecting rod bearing damage.
Welded stuts on the engine block
One camshaft has beat traices
One camshaft bearing cap is of a different engine.
KR
Old Oct 15, 2013 | 03:22 PM
Give them a ring and talk to them about it matey.Surely there is mistake somewhere.
Old Oct 15, 2013 | 03:33 PM
RigPig's Avatar
RigPig
You bought the engine at the start of the year, its October now ?
Old Oct 15, 2013 | 06:25 PM
Cossiemainful's Avatar
Cossiemainful
as above speak to them. its a company so I guess you have at least 1 year guarantee/warranty and even if you bought the product in january, its not too late for a claim. good luck.
Old Oct 15, 2013 | 06:35 PM
bigchez's Avatar
bigchez
True, but if he's building a project car he may well not have got round to installing the engine till now if he's been working on other things.....
Oppliger seem well regarded on here, sure they'll sort it.
Old Oct 15, 2013 | 06:39 PM
turbo965's Avatar
turbo965
I bought the engine in May. After installation in July, I've written several times Mr. Oppliger. Unfortunately, no concession on his part.
Old Oct 15, 2013 | 06:40 PM
rog's Avatar
rog
I'd email them and call them, but don't expect a speedy response
Not being funny but I wouldn't have touched the engine, unless you'd spoken with them first, you end up just wasting your own time and money doing that and there is always an element of doubt over who/when/where was responsible for the damage.
Old Oct 15, 2013 | 06:50 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Not good to hear I'm thinking of buying a block and crank off him as he gives very good prices! Been chatting to him on Facebook about it 500 for a standard grind crank and 650 for a 200 block
Old Oct 15, 2013 | 07:01 PM
turbo965's Avatar
turbo965
hi,
can someone set photos for me? Would they send it by mail.
Old Oct 15, 2013 | 07:35 PM
Cossiemainful
Originally Posted by turbo965
hi,
you have a PM....
Old Oct 15, 2013 | 07:44 PM
LHD220Turbo's Avatar
LHD220Turbo
Oppliger is/ was a trader on here, maybe he will see this thread.
Old Oct 16, 2013 | 07:32 AM
Oppliger Motorsport's Avatar
Oppliger Motorsport
Romain
hello,
the engine you bought was used (ok with 1000 miles) and was working on a westfield with dry sump.you have ask to buy the engine with normal wet sump.
its not my fault if you was on the dyno without set the carburators and the ignition.the engine on your dyno was running very lean and with probably to much advance for your fuel.this is the reason for the piston damage.
Ok the engine had a liner fitted and a different cam cap on the head but this is not a problem.
its absolutely not true about not responding emails as i have all the emails with exchanged during summer.i have offer him to give an other 205 block and a set of pistons but instead of solve the difficult situation between us he prefered send a letter from a lawyer.
the engine was originally coming from UK and we did some work on it.
Old Oct 16, 2013 | 08:47 AM
Bloomers's Avatar
Bloomers
Cornish Fasty
was that out of a red one that someone on here bought?
Old Oct 16, 2013 | 08:49 AM
Oppliger Motorsport
Romain
hi,
no from a yellow westfield imported in italy by a guy 2/3 years ago
Old Oct 16, 2013 | 08:59 AM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
So he bought a second hand untested engine and is complaining because it went wrong?
isnt that part of the game? you buy second hand unwarrantied bits, you accept the risk.
Old Oct 16, 2013 | 09:27 AM
It's Czech Mate's Avatar
It's Czech Mate
Originally Posted by Oppliger Motorsport
hello,
its not my fault if you was on the dyno without set the carburators and the ignition.the engine on your dyno was running very lean and with probably to much advance for your fuel..
Case Closed
OP
Old Oct 16, 2013 | 09:35 AM
turbo965's Avatar
turbo965
If I buy an engine with a carburetor, then I assume that the nozzle assembly is correct. Therefore, the piston can not but strike the cylinder head! What good is a block and piston when the connecting rod is annealed
Old Oct 16, 2013 | 10:40 AM
Jay,'s Avatar
Jay,
Sponsor
Been waiting 2 months for a price on a gearkit there useless
Old Oct 16, 2013 | 10:44 AM
turbo965's Avatar
turbo965
the engine has been set and checked by Rüddel Racing
http://www.rueddel-motorsport.de/
click Galerie
Old Oct 16, 2013 | 10:59 AM
Oppliger Motorsport
Romain
i'm sorry hear this,have you got a reply from us?i had a lot of emails undelivered by the tiscali server.
Old Oct 16, 2013 | 11:01 AM
Oppliger Motorsport
Romain
when you bought the engine you told me that the twin dellorto 48's will be removed to fit smaller 40's ones
Old Oct 16, 2013 | 11:12 AM
turbo965's Avatar
turbo965
Of which was never mentioned. You said (of witnesses) the 40mm carbs are better for the street. But there were always built 48er carburetor.
Old Oct 16, 2013 | 11:32 AM
ajamesc's Avatar
ajamesc
You get a reply off them the same day with prices via Facebook They have a page on there listing what the do seem very helpfull as well!
Old Oct 16, 2013 | 03:05 PM
Jay,'s Avatar
Jay,
Sponsor
i would rather chew my own testicles off than join facebook
Old Oct 16, 2013 | 03:27 PM
cosworth racing's Avatar
cosworth racing
I agree!
I ended up with buying a dogbox from Sweden instead
Old Oct 16, 2013 | 03:28 PM
ajamesc's Avatar
ajamesc
Ha ha it's not that bad mate in fact it's a usefull tool
Old Oct 16, 2013 | 04:26 PM
Spiky's Avatar
Spiky
Jay is a little behind the times, he still thinks his "vest" is in fashion
Old Oct 16, 2013 | 04:47 PM
james kiely's Avatar
james kiely
amen
Old Oct 16, 2013 | 05:06 PM
Mr RS500's Avatar
Mr RS500
It is a usefull tool ,, its also full of tools
Old Oct 16, 2013 | 05:08 PM
ajamesc's Avatar
ajamesc
So people say but as I only add friends family and things I'm interested in I've not seen that side of it lol
Old Oct 17, 2013 | 03:43 PM
Cossiemainful
have uploaded the pics for "turbo965"
Old Oct 17, 2013 | 06:48 PM
mk22door's Avatar
mk22door
Fart of the Purniture
Aahh, a man after my own heart
Old Oct 17, 2013 | 06:59 PM
coswurv's Avatar
coswurv
I don't think you have anything to complain about, if oppliger got the engine in a running track car and it ran ok, there not gonna strip the engine down to every single component and check it before selling it are they. Then if you've put smaller carbs on it and wacked up the advance I'm not surprised by the bore marks and bearing shell.
Old Oct 17, 2013 | 07:17 PM
Eagle's Avatar
Eagle
Super Moderator
Old Oct 17, 2013 | 07:35 PM
costina's Avatar
costina
Live long and prosper!!
arp studs in a 205 block
bet its the 2nd stud exhaust side...
If it was set up correctly and not stripped then op might have done something to help you out.
Old Oct 17, 2013 | 07:53 PM
turbo965's Avatar
turbo965
Mr. Oppliger did not say that the engine off 2 Hand. He explained that the engine was built by him and is just run-in. In addition, no smaller carburetors were mounted.
I knew that the engine is from a race car, I would have never bought the engine!
Old Oct 18, 2013 | 11:54 AM
turbo965's Avatar
turbo965
Here is the text with which the engine was offered.
cosworth YB N/A 250hp complete engine new ID# : 68792 ; Date posted : March 26, 2013 ; Expire date : August 8, 2014 ;
Factory date: 2012
Price: 6000 euro
Details: for sale a new build and only done running in cosworth YB N/A 250hp dry sumped complete engine we are selling due to changing to turbo application the spec of the engine is: dellorto twin 48's carbs (rebuild) with pipercross filter forged pistons 11.5:1 cr H section con rods pace dry sump 3 stage pump ported head with cams,verniers arp studs all aorund cranck+flywheel+clutch balancing (clutch not included in the sale) ceramic coated exhaust manifold
Contact Name: Oppliger Motorsport
Contact Phone: +39 3921510898
Old Oct 18, 2013 | 12:44 PM
boy-racer-1's Avatar
boy-racer-1
looks like a clasic case of the engine was built, the engine was used, it developed a problem, it was sold off to some wolly with the hope of no comeback, i dont think people realise this happens alot more then what people think
Old Oct 18, 2013 | 01:25 PM
turbomook's Avatar
turbomook
I got a reply next day regarding buying a gearkit, and have had updates about when the kits will be ready to pay for and be shipped. Prices are also on his website mate.
Old Oct 18, 2013 | 01:42 PM
Oppliger Motorsport
Romain
let explain the situation
the engine was already on a westfield bought from UK,the engine had a problem
so we strip it pieces,the engine spec was not good for road use as the cams was too wild,the carbs too big....
we rebored the block,change pistons and rods,new engine bearings,new multilayer head gasket, and new fast road cams from newman.
after this the engine was back on the customer car and he did with it the running in for about 1000km
by the time the customer was after more power and more usable engine so he asked for a Turbo YB engine.
the engine setting with these cams and new cr (compression ratio) was never done for after 5500rpm to 8000 rpm as it was in running in
when the German (turbo965) customer bought it he asked me to remove the dry sump system and i put a normal wet pump,he also told me that he will fit smaller carbs.
as he was on dyno with the engine....why dont stop pushing if you see with the wide band that fueling is lean and with knock sensor there is detonation
