Boostmonkey ECUs
Old Oct 11, 2013 | 07:54 AM
marky_g's Avatar
marky_g
Fleet Manager
Default Boostmonkey ECUs
As above stumble across there website
Wondering if anyone's used them
What's it like?
Results?
Old Oct 11, 2013 | 08:34 AM
chink's Avatar
chink
i might be wring but doesnt karlos g use one
Old Oct 11, 2013 | 09:24 AM
marky_g's Avatar
marky_g
Fleet Manager
When the guy told me someone in here was using one I instantly though of Karols lol
Old Oct 11, 2013 | 10:12 AM
Brendan's Avatar
Brendan
struggling with reality
I am considering one for my fiesta! but I need to finish the curent upgrade first!
Old Oct 11, 2013 | 11:44 AM
studabear's Avatar
studabear
Looks a very good kit, Rob from boostmonkeys sent me a copy of the instruction manual, very well written and easy to follow, a few people are running them, obviously results will vary dependent on mapping.
Old Oct 11, 2013 | 11:52 AM
R4N SS's Avatar
R4N SS
how do these compare to omex 600?
Old Oct 11, 2013 | 11:57 AM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
Wasn't Stu supplying and mapping these?
Old Oct 11, 2013 | 12:01 PM
kingbx95's Avatar
kingbx95
Robs a top guy, very helpfull!
I'm currently waiting on his new ecu which is a mega squirt based ecu using automotive grade cases etc
Looks to be a great bit of kit and well
Priced too
Old Oct 11, 2013 | 01:54 PM
SiZT's Avatar
SiZT
It's just megasquirt afaik
Old Oct 11, 2013 | 06:05 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Priced too
I've been using Boost Monkeys ECU's in all sorts of builds not just my own car for the last year or two.. BMW's, VW's, Various Ford's, etc.
Can't recommend them enough, the build quality is excellent and in my opinion they are are by far the best value for money out of all after market management.
Rob is in talks with Stu yes.
As said Rob who runs the company is a really friendly helpful guy
Old Oct 11, 2013 | 08:20 PM
R-A-J's Avatar
R-A-J
These ecu's do more than omex 700 in standard form I think? to give you an idea on the company, I was on the hunt for a ms ecu, I found one on here and contacted them for some advice, I basically said is it good enough for my needs or would I be better buying one of theirs, Rob could of said theirs would of been the best option, but he was very honest and said for what I needed the one off here would be fine. This goes to show what a decent and honest bloke he is, could of sorted me out to buy one of his but instead looked at the best option from the customers point of view.
My next ecu will be coming from here for sure!!!
Proper company run by proper enthusiasts!
Old Oct 12, 2013 | 12:17 PM
marky_g's Avatar
marky_g
Fleet Manager
Sounding pretty good then who maps mega squirt in Essex?
Old Oct 12, 2013 | 12:31 PM
Mk4 Rick's Avatar
Mk4 Rick
Do they do the ecus for fords eec-v?
Old Oct 12, 2013 | 12:37 PM
SBT83's Avatar
SBT83
I'll be buying from Boost monkeys then
Karlos since we're mates how's about you come to mine to map and I'll buy you a Big Mac meal for it?? Go on then, you can have flurry too
Old Oct 12, 2013 | 01:11 PM
studabear's Avatar
studabear
Rob is down your way, he might map it for you.
Old Oct 12, 2013 | 01:14 PM
rsmark86's Avatar
rsmark86
There's a few people using them and all with very good reviews
My advise! Take you loom out and check it as I have been through 3 to find the perfect one
Old Oct 12, 2013 | 01:23 PM
rsmark86's Avatar
rsmark86
Zac at power engineering
Chip ...... On here, very experience with ms based ecu's
Rob himself
Jano told me he was prepared to mapp one too
Karlos g as above
And as meantioned stu at msd is very interested in robs ofam ecus
Old Oct 12, 2013 | 04:30 PM
rsmark86's Avatar
rsmark86
What wideband controller would everyone use for the ofam?
Old Oct 12, 2013 | 05:31 PM
studabear's Avatar
studabear
aem should be fine, I use it on my ms2 ecu
Old Oct 12, 2013 | 06:37 PM
Mk4 Rick's Avatar
Mk4 Rick
Do they do eec-v ecus?
Old Oct 12, 2013 | 06:41 PM
martinmilne's Avatar
martinmilne
yeah great kit had one for while now robs great bloke always helpful
Old Oct 12, 2013 | 07:28 PM
rsmark86's Avatar
rsmark86
Cool will look into it, I'm going too get the boost solenoid for it too
Old Oct 12, 2013 | 07:30 PM
studabear's Avatar
studabear
if got the aem boost solenoid too, I think rob can supply solenoids so might be worth checking with him.
Old Oct 12, 2013 | 07:59 PM
rsmark86's Avatar
rsmark86
Yeh I'm hoping to just buy it all as a kit, as I wouldn't know where too plug it all in lol
Old Oct 13, 2013 | 07:59 AM
marky_g's Avatar
marky_g
Fleet Manager
Yer I have a lamba hole welded into my exhaust when I sent it away for repair so would most Likly have that fitted, sure mines done the same way as Karlo's I believe, using later escort xr3i efi that's the same as a Cvh xr2i's loom
So rob is the owner at boost monkey? And there actually based in essex? Might have to send him an email then as I'm struggling to find anyone even willing to take it on because of the way it's been converted
Old Oct 13, 2013 | 09:20 AM
rsmark86's Avatar
rsmark86
Aslong as the pin outs are correct and everything works there shouldn't be a problem
If I was you mate I would travel too the right tuner to get the job done right
When I spoke to rob he is willing to mapp them but has a long waiting list due too high demand
Take it too karlos g, he will understand the conversion loom and check its correct and work from there and be able to do it a lot sooner, and he's very experienced with ms based systems
As is chip on here
Old Oct 13, 2013 | 09:27 AM
marky_g's Avatar
marky_g
Fleet Manager
Spoke with Karols abit in the past we also swapped a few parts as I believe he built his cvs from an xr3i efi block shall have to pick his brains lol
Old Oct 13, 2013 | 09:31 AM
rsmark86's Avatar
rsmark86
Just order your ecu, some vxr injectors and drop it off with him
He's very well priced for a remapp, and heard nothing but good reviews
Old Oct 13, 2013 | 10:24 AM
marky_g's Avatar
marky_g
Fleet Manager
Cool what vxr injectors do I want lots of corse one 470cc??? Do they fit directly into the standard fiesta rail?
Old Oct 13, 2013 | 11:23 AM
rsmark86's Avatar
rsmark86
Yes they fit straight in as I said in the other thread
The engine is a z20leh astra vxr, this is the model injector you want
They can be picked up for £75/100 depending on availability
Old Oct 13, 2013 | 11:43 AM
SBT83's Avatar
SBT83
If not I have a brand new vxr fuel rail with fpr
Old Oct 13, 2013 | 12:07 PM
rsmark86's Avatar
rsmark86
They fit mate, I've had them in a blacktop inlet, frst inlet and now in my modded zetec inlet
Old Oct 13, 2013 | 01:05 PM
marky_g's Avatar
marky_g
Fleet Manager
The hunt is on
Old Oct 13, 2013 | 03:15 PM
rsmark86's Avatar
rsmark86
Good man
Old Oct 14, 2013 | 09:52 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Lol an offer I can't refuse right there!
As is chip on here
I personally prefer making up a fresh loom when changing management, so much time can be wasted fault finding 25 year old looms, as Mark says he went through three before getting a good one.
Old Oct 14, 2013 | 09:55 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes they fit but only flow for around 225bhp safely, I would go with Siemens Deka V's as they are only £200 brand new and you then have scope for decent power.
Old Oct 14, 2013 | 01:58 PM
rsmark86's Avatar
rsmark86
Defo the Siemens are good but he's only running a standard cvh with t3 so wouldn't they be a bit over kill?
He will be maxed out before 200bhp?
Old Oct 14, 2013 | 02:25 PM
marky_g's Avatar
marky_g
Fleet Manager
I've just got to get it actually running before I bother with power lol but 200 isn't an unreasonable price for new when I'm looking at 120 for vxr stuff
Old Oct 14, 2013 | 08:11 PM
rsmark86's Avatar
rsmark86
Get them then bud
You will most likely never need to change them again
Old Oct 14, 2013 | 08:26 PM
studabear's Avatar
studabear
You can import the deka's for less than £200, if you put that they are a gift and get away with it you could pay around £150
