LPG.Good or bad??? those in the know..
Old Oct 10, 2013 | 08:39 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
Default LPG.Good or bad??? those in the know..
Considering a project in the future that would run a modern alloy v8 ls1 etc but due to fuel costs would have to run on lpg...
I have been told (true or not ) that the engine will carbon up and the lpg will knacker it
Is this true or just a load of baloney
Also any other downsides to running on lpg ?
Ta.
Old Oct 10, 2013 | 10:17 PM
JonnyBravo's Avatar
JonnyBravo
The engine should be perfectly happy on LPG, I have converted many of the slightly older LS series engines.
Kit wise, don't skimp, use a fully sequential system, Prins would work very well and has for me given proven results, good economy and reliability.
Old Oct 10, 2013 | 10:42 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
do they actually make the engine more economical as in, if you average 25mpg on shell nitro+, then lpg it, wouldn't you still get 25mpg but the lpg costs less to buy?
Old Oct 10, 2013 | 10:48 PM
JonnyBravo's Avatar
JonnyBravo
On average you lose 2-3mpg on a good setup, LPG is generally half the price of pump fuel, in some cases less than that if you find a better source for it.
Old Oct 10, 2013 | 11:05 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
cool, cheers for clearing that up lol
Old Oct 10, 2013 | 11:10 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
i came on this post suggesting you contact JonnyBravo...............
my hairy crystal balls worked very well lol
and as the lad says,
buy the best, and economy wise little loss on power = few mpg less but its the pump price that makes people convert.
dont get owt done without a certificute
Old Oct 11, 2013 | 05:57 AM
p.cressie's Avatar
p.cressie
Just noticed a scooby wrx running on lpg near us. Anyone heard how these run on lpg?
Old Oct 11, 2013 | 06:16 AM
boost monster's Avatar
boost monster
I know two people who have been running lpg for years ( v8 jeep and a camper van) they have never had any problems.
The only issue I would have in my part of the country is the availability, I would have to go out my way too refuel.
Do it!
Old Oct 11, 2013 | 06:31 AM
Cragrat's Avatar
Cragrat
sit boo boo sit
Result.been given rough prices of circa Ł1600 to convert,sound about right ?
Will all be done with proper paperwork as pointless otherwise
Now can a supercharger be a viable option with lpg?
Old Oct 11, 2013 | 08:40 AM
JonnyBravo's Avatar
JonnyBravo
Ł1600 is a fair price for a v8. What system is that using ?
No issues doing a supercharged engine, injectors would need to be suitable and you will probably need twin vaporizers. I've done a fair few f150 lightnings with heaps of power and they all worked great.
Old Oct 11, 2013 | 11:16 AM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
There used to be a rally school with a pair of escort cossies running lpg
Old Oct 11, 2013 | 11:27 AM
Cragrat's Avatar
Cragrat
sit boo boo sit
Not sure what system,was just testing the water so to speak
What set up would you recommend,looking at a pretty much stock spec with 3-360 bhp,as don't want to stress the lump but have plenty of torques
Supercharger would be a later mod
Old Oct 11, 2013 | 12:00 PM
JonnyBravo's Avatar
JonnyBravo
Phil Price in Wales. He uses it on all the cars I believe. The Escort was on a Romano system iirc.
I've only been involved with the higher end systems which are all quite pricey. Generally anything with a v8 in was around Ł2200 from memory.
If it was my car I'd use a Prins Multipoint system, one vaporizer, the biggest tank you can get in there ( tanks fill to 80%) of their capacity.
The only issue with Prins is I believe they can only be installed by dealers now as all vehicle info needs to be kept for their records.
Old Oct 11, 2013 | 12:08 PM
bigpaul's Avatar
bigpaul
I run my daily driver 1.8t audi tt on it, no problems with it besides takes bit of time to fill up tanks compared to petrol . I get 240 miles to Ł28 gas , do lose bit of mpg but cheaper cost of lpg makes up big saving.
Old Oct 12, 2013 | 12:59 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
Anyone gave it ago with cheap kits from eBay?
http://www.ebay.co.uk/itm/STAG-4-Q-B...item27d75b5dc5
Fordmad!
Sep 29, 2015 07:03 PM
Fiddy
21
Sep 29, 2015 06:10 PM
A.t.p
Sep 29, 2015 05:04 PM
Minirotty
11
Sep 15, 2015 10:16 PM
