No longer for sale
Old Oct 8, 2013 | 10:09 AM
rsmark86's Avatar
rsmark86
Default No longer for sale
I'm just testing the water as I'm bloody skint and need a everyday car (would like a sporty ford) and my house move has near bankrupted me and it's stupid too leave it sitting in the garden
It's a imperial blue fiesta rst that was owned and restored by Chris the painter from the ox- ford group and is in really nice condition apart from a few small scuffs and stone chips
It is unfinished because it needs either a chip or a ofam ecu too finish and a set up, it's a running nearly finished project and I can have it all done ready for chip and injector swap ready to rock and roll
ENGINE:
2.1 silvertop zetec turbo
Lightened and balanced
Shot peened rods
Arps
C20let pocketed pistons
Decked block, skimmed and pressure tested head
Devil developments valve springs
Focus rs gaskets with multi layer head gasket
Zetec inlet modified for custom fuel rail and fuel reg for top feed injectors
Vxr injectors
Modified frst charge pipe to fit zetec
Rouse Motorsport hybrid hose coolant hose kit for perfect fit
Airtec stage 2 rad mounted right in front panel too clear turbo
Grs front mount intercooler
Breather kit
Cosworth 4x4 t3 in perfect condition
Head modified for cvh ex mani, ( properly welded and skimmed for perfect surface)
3" downpipe with lamba with 3"- 2.5" reducers
Up rated fuel pump
Vibratechnics g/box mounts
Single big spal fan
Transmission
Bc box ( lol)
Uprated pedal mod (adjustable clutch)
Up rated g/box mounts
Pretty good gear linkage
Suspension/brakes
New'ish gmax 3.5 fiesta kit
Mk3.5 long studded hubs+ spacers
Rear axle widening kit (on way today)
Rose jointed lower arms (solid bushed)
OMP front strut brace
Cosworth 4x4 calipers
Tarox drilled and grooved discs
Ebc green stuff pads
Custom brackets/spacers not stupid washers stuck together
Braided brake lines
16" white team dynamics pro race 1.2s with nearly new matching tyres
This project has quite a few spares and bits too do but as I said I can get it ready if a deposit is left or take it now with a car full of spares
Bad bits
Needs a chip and injectors to suit spec (but runs)
Needs abit of finishing /detailing
Very dirty as been sat about for 3 months (but I will get the sponge out lol)
Wheels are not mint but are presentable
Rocker cover could do with painting
Exhaust could do with playing around with to get perfect fit
And maybe a few others, I'm stressed out my mind trying to do the right thing but my 2nd daughter is due in 10 weeks are as previously stated I just got a brand new house and there has been so many expenses that I didn't realise I had too spend.
Looking for a quick sale otherwise I will break, there's most likely loads of parts I forgot about, I worked out it would break for over 3.5k so want £2.5k cash for every ford part I own and the whole project
Or will px swap for something nice
A couple of pics coming
07825348906
Old Oct 8, 2013 | 10:11 AM
rsmark86's Avatar
rsmark86
By the way the head rebuild and frs gaskets, water pump and timing belt kit and devils springs were just fitted and done zero miles
And also had
Arb poly bushes
Drop links
Steering knuckle and so on
Old Oct 8, 2013 | 10:19 AM
rsmark86's Avatar
rsmark86
I will get better pics for anyone but it's a car that needs too been seen
It's a very pretty car when cleaned and waxed ect
Attached Thumbnails No longer for sale-image-929358249.jpg   No longer for sale-image-2835502334.jpg
Old Oct 8, 2013 | 05:04 PM
rsmark86's Avatar
rsmark86
Would even consider another rst that I can just get in and go as px or swap
But really want something like a mondeo st, st170 or rs2000 ect
As said I'm on the verge with breaking it as it's worth a lot more but let's see how it goes
Old Oct 8, 2013 | 06:42 PM
RS-Mitch's Avatar
RS-Mitch
Known VW hater
mate thats a shame but glws
Old Oct 8, 2013 | 07:14 PM
rsmark86's Avatar
rsmark86
I know bud but it's a matter of no money and no motivation too build them anymore
Just want a car too get in and go
Old Oct 8, 2013 | 07:26 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
Gutted your selling mate looks like a nice thing
Old Oct 8, 2013 | 07:39 PM
primedog's Avatar
primedog
what chip would you say it needs, an off the shelf item like 195 superchip or custom?
Old Oct 8, 2013 | 07:41 PM
NC53's Avatar
NC53
Mark, if you do break it I might be interested in the engine.
Old Oct 8, 2013 | 07:57 PM
rsmark86's Avatar
rsmark86
Msd do an off the shelf zetec turbo chip for cossie t3 and iw-158 injectors for £250
But a 195 would work for now with biege injectors but it would be restricted too 220bhp and that's stupidly low boost
Old Oct 8, 2013 | 07:58 PM
rsmark86's Avatar
rsmark86
Let me know mate what you want, if someone buys a big chunk it will push me too break it, will need to find a buyer for the shell but can just ebay it
Old Oct 8, 2013 | 08:02 PM
Seanoc84's Avatar
Seanoc84
Newbee
Where abouts are you?
Old Oct 8, 2013 | 08:04 PM
rsmark86's Avatar
rsmark86
Bracknell
Berks
Old Oct 8, 2013 | 08:14 PM
Seanoc84's Avatar
Seanoc84
Newbee
That's a nice motor, got an st170 03 imperial blue.
Just fitted engine and gearbox from 60k accident damaged car as I bought it with cambelt snapped.
Car itself has done 127k
Cars pretty clean but clutch is slipping at 5.5k revs in 3rd and above.
Drives fine normally also no noises from dmf.
Let me know if ur interested.
Sean.
Old Oct 8, 2013 | 08:42 PM
rsmark86's Avatar
rsmark86
Depends what deal you are thinking bud
Old Oct 8, 2013 | 09:17 PM
NC53's Avatar
NC53
Basically everything you have listed under the headings Engine & Transmission except the linkage. PM me a price or put it up on here, whatever you prefer.
Old Oct 9, 2013 | 06:47 AM
rsmark86's Avatar
rsmark86
Pm'd bud
Old Oct 9, 2013 | 06:40 PM
rsmark86's Avatar
rsmark86
Bump ..... Might just break it
Old Oct 9, 2013 | 09:56 PM
primedog's Avatar
primedog
my mate has a frst in black, taxed n mot'd, had an uprated clutch put in feew months bak, 195 chip n beiges etc that sort of stuff. not a bad looking car, goes well, made over 160bhp at power engineering before the clutch started slipping but hasnt been back since. i told him of ur car and hes interested but he can only do straight swap as yours needs money to get it sorted and his is on the road. if it apeals to u let me no il send u pics. has usual rust around filler cap n couple odds n sods that could do with tidying but its not a shitter.
Old Oct 9, 2013 | 10:18 PM
rsmark86's Avatar
rsmark86
pm'd ................
Old Oct 10, 2013 | 04:04 AM
Gadget's Avatar
Gadget
Spanner monkey
Mark
How much for the bottom arms if you break?
Old Oct 10, 2013 | 05:18 AM
rsmark86's Avatar
rsmark86
pm'd...........
Old Oct 11, 2013 | 09:46 PM
rsmark86's Avatar
rsmark86
bump........... final push otherwise might break or lock up for a year or so
Old Oct 12, 2013 | 04:45 PM
rsmark86's Avatar
rsmark86
Please remove
I'm keeping it
Old Oct 12, 2013 | 06:11 PM
dake205's Avatar
dake205
I'm really interested in your engine pm me a price
Old Oct 12, 2013 | 06:32 PM
Roscopeco's Avatar
Roscopeco
Originally Posted by rsmark86
Please remove
I'm keeping it
Nice one
Old Oct 12, 2013 | 07:26 PM
rsmark86's Avatar
rsmark86
Originally Posted by Roscopeco
Nice one
Yeh it's less than I was thinking too finish. All I need is a chip and injectors or a ofam ecu and set up and it's done
Old Oct 12, 2013 | 07:29 PM
simsytall's Avatar
simsytall
series 1
your keeping a car
Old Oct 12, 2013 | 07:57 PM
rsmark86's Avatar
rsmark86
I know, there's a first for everything lol
Old Oct 12, 2013 | 08:39 PM
Dubs44's Avatar
Dubs44
go ofam and keep your vxr's. a chip and 158's will cost you the same as an ofam ecu. just run it round on a base map for a while then have it mapped at a later date imo
Old Oct 12, 2013 | 09:07 PM
rsmark86's Avatar
rsmark86
Might aswell
I can always add the wideband ect at a later date
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
DavidK
Sep 27, 2015 02:55 PM
