Over head cams and over head values?
Old Oct 7, 2013 | 09:34 PM
Cossie.jack's Avatar
Cossie.jack
Default Over head cams and over head values?
Hi all,
I need some help here, my collage tutor has told me to research into the advantage and disadvantages between the over head cams and over head values. Try searching google not much there, could any one explain for me?
Thanks Jack
Old Oct 8, 2013 | 08:48 PM
focusv8's Avatar
focusv8
Your Google must be having a bad day;
https://www.google.co.uk/search?q=ov...Oqqw0wX7mYDYBQ
Old Oct 8, 2013 | 10:17 PM
Cossie.jack
Lol it was on my iPad I couldn't get much, got on the computer and got loads? Weird, anyway got all my info thanks!
Old Oct 8, 2013 | 10:40 PM
stevieturbo's Avatar
stevieturbo
C**t
Or you could always look at each design....and decide for yourself pro's and cons for each design, rather than googling for other peoples ideas.
Old Oct 10, 2013 | 12:19 PM
martysmartie's Avatar
martysmartie
OHV is an older design, the camshaft is in the block and the valves are actuated by push rods, disadvantage is they have more mass, I think I am right in saying these engines typically do not rev very high for this reason either? I can't think of an advantage off hand.
OHC is a modern design, and as the name suggests, the camshaft is in the head and actuates the valves directly. The advantage is less mass and fewer moving components.
Martin
Old Oct 10, 2013 | 07:44 PM
Karlos G's Avatar
Karlos G
Balls Deep!
It's probably because you were searching for over head VALUES and not valve mate?! lol
Old Oct 10, 2013 | 08:12 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
advantage of an ohv with pushrods is unlikely to bend valves if belt slips.
disadvantage is more mass and more clearances to take into account of rod to cam and rod to rockers.
ohc is better for power (gains and losses)
Old Oct 10, 2013 | 11:11 PM
Cossie.jack
Lol
Thanks all for your replies
Old Oct 11, 2013 | 12:05 PM
martysmartie
Are you sure? These engines have chains, but regardless if the timing was out a mangled mess would be the result, assuming an interference engine?
Martin
Old Oct 11, 2013 | 03:46 PM
The ohv ford engines had a chain and a tensioner.
Old Oct 12, 2013 | 04:34 PM
martysmartie
Correct, as does every engine of this kind I know of!
The interesting one is Fords 1L Ecoboost which has an integral belt, which supposedly is 'for life'!
Martin
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
IainRS1700T
Sep 25, 2015 06:44 AM
timsrs
22
Sep 24, 2015 08:14 PM
dombanks
Sep 21, 2015 08:38 PM
CrOwSoN15
Sep 14, 2015 11:33 AM
