Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
2.0 zetec mondeo
Old Oct 4, 2013 | 07:50 PM
Pockets2012's Avatar
Pockets2012
Default 2.0 zetec mondeo
Hi guys I got a chance to buy a mk2 mondeo complete for 150
I take the 2.0 Zetec turbo same engine just with turbo ???
Any idea how much would the parts cost to mak it turbo
And would the sump need adjusting or could I buy a diffrent one ??
Old Oct 7, 2013 | 05:27 PM
gjh's Avatar
gjh
Ye its a 2.0 with a turbo added, but there's a bit more to it than that, like you will need a different inlet as the standard one wont flow enough, same with fuel injectors, probably uprated valve springs, different engine management etc. Its said that it can be done for about Ł1000 butI'd budget Ł2k just in case, I believe you can use the standard sump, not sure if any modifications are required though.
Old Oct 7, 2013 | 05:40 PM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
Oil feed from block, oil return to sump, manifolds, gearbox, LSD, valve springs, decomp plate, sump depending on exhaust setup, arp con Rod bolts (can get away with), injectors, spark plugs, decent breather setup and a turbo. Pretty much a rough guide but you'll find plenty if info around here. Gjh is right have a budget of up to Ł2k. I've bought most of my setup and I'm under a grand at the minute but you'll be looking at another Ł600+ with all the ancillary parts and fitting
Old Oct 7, 2013 | 06:29 PM
Pockets2012
That ok I'm gonna rebuild the engine before its fitted to my mk4 fezz
I was just wondering what parts would I need to run a turbo
I know intercooler turbo manifolds intercooler pipes but what eles is needed can't rember off the top of my head gone blond lol
This is a list of what I would like to do bearing in mind this is gonna be a slow project
2.0 zetec with turbo (t38)
Forged piston/rods. C20let cavalier or rs or mondeo
2.1 block with uprated valves
Aftermarket throttle biddies
Rear discs
Mtx75 gear box
Focus rs front discs
Rs gasket set or one suitable for 500 bhp
Uprated water pump/oil pump
Race clutch
Balanced fly wheel
LSD
Arp bolts all round
Heavy duty bearings
Coil overs
Ecu remapped with multi maps I hope one for fuel save for long travels sport and track
750cc injectors
Gauges
Set of mk5 fiesta twins with sports cat
I'm looking for 400 bhp with room to breath also gonna put a 150 noz shot
mk3ste
Oct 17, 2021 10:09 AM
wowk
Mar 30, 2021 07:49 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
The Enigma
Sep 29, 2015 10:31 AM
