what brake pads for ap5200 calipers
Hi ime looking at new pads for the ap calipers on my fiesta, I have fedro ds2500 ones at the moment but they dont fell very good, they are ok when hot but when cold there rubish, what pads are good for fast road use, I have looked at the cosworth streetmaster pads but thats about it
I'd strongly recommend the opposite to that if he's getting poor cold performance with DS2500's, DS3000 will be way worse! I'd look at the set up as DS2500 should be absolutely fine.
There's loads of factors that could cause poor braking, master cylinder bore is one.. Have you ever had them working to your satisfaction??
Never really had them working aswell as I think they should be.replaced the master clyinder with one off a mk5 fiesta (alloy one not steel) and the brakes are better than they where with the ka one I had on there.i haven't changed the discs and pads since I bought the setup second hand.only rebuilt the calipers. Could the wrong thickness discs cause any issues(too thin)
I changed from ds2500 to pagid rs14. The ds2500 i thought was a great pad. Good bite from cold but it wrecked my discs with leaving pad deposits on it. I dont think pad change will make your brakes any better. Maybe youve glazed them. Go out and give them death see if i makes it any better
