Bought myself a new toy... E46 M3 Supercharged!!!
Old Oct 2, 2013 | 02:33 PM
DanCossie's Avatar
DanCossie
Post Whore
Default Bought myself a new toy... E46 M3 Supercharged!!!
Just done a deal to purchase this new toy
NOW before I get killed !! there are a lot of bits to change including Interior, Wheels, and probably remove the wrap but its all cosmetic!!
It does have some nice bits though including Alcon 6 pot Front Brakes, Full Carbon GTR Bonnet, Very nice stereo system, full stainless system front to back!!
Here it is
And the main bit!!!!
Old Oct 2, 2013 | 02:35 PM
stu21t's Avatar
stu21t
This will be very cool.
Most importantly where's the rr graph?
Old Oct 2, 2013 | 02:37 PM
DanCossie's Avatar
DanCossie
Post Whore
They are a lot of fun! plus has the best supercharger kit ( VF Engineering ) It has 4 stages and this should be stage 2 which is 480bhp
Old Oct 2, 2013 | 02:39 PM
cfoster's Avatar
cfoster
Very nice mate but deffo remove the wrap, take your time and buy a decent adjustable temp hot air gun otherwise laquer may come off with it!! I take it its Laguna Blue underneath?! (my FAV colour!!)
Chris
Old Oct 2, 2013 | 02:44 PM
stu21t's Avatar
stu21t
Surely the engine bays not been wrapped too? The turrets are dirty white.
A std m3 is quick so this should be very rapid. What torque?
DanCossie's Avatar
DanCossie
Post Whore
Chris
I would get a 'professional' hint hint to do it!!
No its actually silver underneath...
Old Oct 2, 2013 | 02:47 PM
James @ M Developments.'s Avatar
Pretty cool car in there somewhere i reckon, what has been done management wise to fuel for the charger?
Old Oct 2, 2013 | 02:48 PM
DanCossie's Avatar
DanCossie
Post Whore
480 bhp and 340 torgue.. at 7psi
I am looking at that now cheers for spotting it Stu!
Old Oct 2, 2013 | 02:50 PM
DanCossie's Avatar
DanCossie
Post Whore
This should explain it all mate
VF480 Supercharger System
Supercharger system setup for 5.5-6.0 psi, V3-SQ trim supercharger with air/water cooled cartridge inside cast intake manifold. High flow fuel Stage1 injectors with ECU flash.
PSI: 5.5-6.0
Horsepower: 480 (Stock: 333)
Torque: 340 (Stock: 262)
- Custom tuned software flash
- Replacement 5.5-6.0 psi supercharger pulley
- Bypass valve spring upgrade
- Slide-in air/water heat exchanger for intake manifold
- Bosch water pump activated by key power relay
- VF custom molded 3 gallon water reservoir system
- OEM front center water radiator with OEM hangers and water lines
Old Oct 2, 2013 | 02:53 PM
cfoster's Avatar
cfoster
Ok cool I do know of someone that can do this....
Turrets do look white though from the pics whether they got them painted when and if the engine came out?!
Chris
Old Oct 2, 2013 | 03:03 PM
DanCossie's Avatar
DanCossie
Post Whore
Chris
They are all like this apparently!! looked at a few online and they are all the same!
Old Oct 2, 2013 | 03:08 PM
XRT_si's Avatar
XRT_si
Indeed, normally BMW leave the engine bay in base coat.
It is a cool car once the leather/wheels/bonnet/lights and wrap are replaced
Went in a 600bhp dyno proven E46 M3 with a VF Engineering kit on it and it went very, very well.
Old Oct 2, 2013 | 03:09 PM
XRT_si's Avatar
XRT_si
Should mention is also has Alcon six-pots on it
Old Oct 2, 2013 | 03:10 PM
DanCossie's Avatar
DanCossie
Post Whore
Yep...and just checked and genuine Carbon GTR Bonnet is Ł1000
Old Oct 2, 2013 | 03:26 PM
rog's Avatar
rog
Good purchase, I can see why you bought it, and can make it look "normal" in a weekend!
Old Oct 2, 2013 | 03:44 PM
pani_k's Avatar
pani_k
PassionFORD Member
Must go like stink! You'd probably recoup quite a bit selling off the undesirable bits and get it looking a lot more subtle.
Cracking motor though!
Old Oct 2, 2013 | 03:53 PM
carlo's Avatar
carlo
Cracking car mate & all the hard work is done
Old Oct 2, 2013 | 04:09 PM
DanCossie's Avatar
DanCossie
Post Whore
Exactly my thoughts! Will get some before and after pics for sure!
My mate had one that wasn't set up properly and had a boost leak and still felt a completely different animal to mine so this will be fun
Cheers Carlo
Old Oct 2, 2013 | 05:00 PM
RS Grant's Avatar
RS Grant
Made in Scotland
Cabrio?! .....oh.
I'd love to show mine some boost.. but the costs of doing so properly from scratch are pretty extreme unfortunately. You are waaay better off buying one that's already done like this. Look forward to seeing its journey back to a more OE-look Dan.
Cheers,
Grant
Old Oct 2, 2013 | 05:04 PM
DanCossie's Avatar
DanCossie
Post Whore
Originally Posted by RS Grant
Cabrio?! .....oh.
Cheers,
Grant
Sod off mine a cab already... the ladies love it
Yeah a good kit is like Ł6000 plus fitting!!
Will do a little resto I think on here
Old Oct 2, 2013 | 05:12 PM
Zetecfiesta's Avatar
Zetecfiesta
Should be a nice motor when you have de chaved it!
Old Oct 2, 2013 | 05:30 PM
Ginge !'s Avatar
Ginge !
just finding my feet
Pikey the car looks perfect for you as it is,,,, lol
Old Oct 2, 2013 | 06:16 PM
streetraider's Avatar
streetraider
I knew of this car when it was silver had black wheels and silver lip.
If its the same one it was based in London but i am sure its the same one.
Imo take it completely back to stock indicators and put diamond cut wheels on and it will look stunning
Old Oct 2, 2013 | 08:12 PM
bigchez's Avatar
bigchez
nice! It's not from Brum is it? Saw one that looked just like that (ie, awful - but I know you're changing it! ) the other day.
Old Oct 2, 2013 | 08:23 PM
DanCossie's Avatar
DanCossie
Post Whore
It is yeah mate lol
Won't take much to take it back to oe!
Old Oct 2, 2013 | 08:27 PM
Less.'s Avatar
Less.
having a mid life crisis
Looks a weapon and sure it will be nice once it been danned
Old Oct 2, 2013 | 08:42 PM
rs old skool's Avatar
rs old skool
im from birmingham..seen this a few times.sounds good
Old Oct 2, 2013 | 08:47 PM
DanCossie's Avatar
DanCossie
Post Whore
Cheers less!!
They do sound good!!
Old Oct 2, 2013 | 08:54 PM
bigchez's Avatar
bigchez
It is yeah mate lol
My car spotting skills are still strong then!
Bonnet looks great in the flesh - it does have some pretty shite aftermarket LED conversion lights too, worth swapping.
Nice buy though - have you sold the other M3 as you said looking for a more sensible daily and unless you're on meth this isn't a sensible daily!
Old Oct 2, 2013 | 09:04 PM
pani_k's Avatar
pani_k
PassionFORD Member
Clients should be impressed though as that was part of the criteria
Old Oct 2, 2013 | 09:05 PM
dan le moignan's Avatar
dan le moignan
Will be good once done, although turrets are weird sure they should be the same colour as the car myne and few others I've seen were.
Old Oct 2, 2013 | 09:09 PM
caprizetec170's Avatar
caprizetec170
Nice motor now all ya need is a blonde mullet
Old Oct 2, 2013 | 09:13 PM
stu21t's Avatar
stu21t
My m3 engine bay is the same colour as the car but just base coat, no lacquer. It just looks Matt.
Would be very strange of BMW to paint the engine bay a different colour to the car. Would be a lot more work for them to mask it up...
Check inside the boot, pull carpets back...
Old Oct 3, 2013 | 07:25 AM
XRT_si's Avatar
XRT_si
Pretty much every BMW has just the base coat in the engine bay. For a silver car it's white.
http://www.detailingworld.co.uk/foru...d.php?t=175058
Old Oct 3, 2013 | 08:26 AM
DanCossie's Avatar
DanCossie
Post Whore
Yeah will get proper lights back in there!
Well I have got a new job but working back in the city so this will be a weekend toy only
See below mate
Old Oct 3, 2013 | 06:14 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
Love that, I have turned into a massive fan of BMW's since owning my E61.
I have also noticed a few Facebook wars on my page between Ford fans and BMW fans, the rivalry is impressive and have seen people fall out over the subject
But, I would love one as a track toy now too.
Old Oct 4, 2013 | 12:30 AM
dan le moignan
I've only seen the poverty models non colour coded, all the M's I've seen are colour coded under the bonnet but not lacquered, had an M3 and M5 and they were both the same, also a friend has a silver/grey M3 and that is silver grey in the engine bay.
Old Oct 4, 2013 | 02:35 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Awesome Dan! I'd love to see what they go like with more power. I bet it feels immense!
Old Oct 4, 2013 | 03:59 AM
andy888's Avatar
andy888
that's the way they all are. close to the colour but not lacquered. silver ones are a kinda white/silver/primer colour under the bonnet. the pictures make that one look more white. my steel grey is a non lacquered grey under the bonnet
Old Oct 4, 2013 | 07:18 AM
angel45's Avatar
angel45
Sweet Jesus it's like a gay blind man did the decor pmsl, explains why I didn't get a reply on fb lmfao
