Escort RST smoke issue please help!
Old Sep 30, 2013 | 02:23 PM
webbie227's Avatar
webbie227
A Webb
Default Escort RST smoke issue please help!
Hi my s2 is excessively smoking on cold start up (blue) and then clearing and no sign of smoke again till the next startup what is causing this? I have a new turbo and engine was rebuilt 5k ago is it possible some oil seals or whatever need replacing already?
Old Sep 30, 2013 | 02:29 PM
studabear's Avatar
studabear
valve stem oil seals would be my first shout, they can be replaced without removing the head with a special tool.
Old Sep 30, 2013 | 02:34 PM
webbie227's Avatar
webbie227
A Webb
I have already had them done but I suppose they could need doing already?
Ok great will try that first I hope this sorts the problem lol
Old Sep 30, 2013 | 06:37 PM
70z28's Avatar
70z28
Hi mate look at you valve guides burton do uprated 1s
Old Sep 30, 2013 | 06:46 PM
Rax's Avatar
Rax
This be careful not to drop a collet.Its long time since doing this but a Ł1 extendible magnet it worth its weight in gold
Old Sep 30, 2013 | 06:57 PM
mgtkr1's Avatar
mgtkr1
yep AND it pays to cover the oil gallerys to minimise the chance of a collet going in the sump
Old Sep 30, 2013 | 06:58 PM
studabear's Avatar
studabear
block the oil returns, I dropped a couple when I was a apprentice many years ago, I left them in as we had some spares from another head. (it was the bosses car)
I've got the tool and a set of seals that I cant ever see me ever needing now I'm running a zetec.
Old Sep 30, 2013 | 07:14 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Seals shouldn't have gone already if they were replaced at build, but it does sound like oil getting into the chambers whilst parked so maybe valve guides are worn?
Or the ring to bore clearance is too big (closes once warm), was it honed or re-bored?
What oil are you using?
Old Sep 30, 2013 | 07:23 PM
webbie227's Avatar
webbie227
A Webb
My tuner said that the bores was honed
I'm using 10/40w oil
What's the next step for me? Maybe rebuild the head completely?
Old Sep 30, 2013 | 07:36 PM
studabear's Avatar
studabear
get the tuner to have a look
Old Sep 30, 2013 | 07:46 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Hmm could be that they are out of tolerance then, who is your tuner and did he build the engine?
10/40w is not the problem.
Not necessarily the head mate.
Old Sep 30, 2013 | 09:05 PM
mgtkr1's Avatar
mgtkr1
mines is the same. im thinking its the turbo letting some seep past or valve guides. it doesn't do it for the first 5 minutes, then it smokes for 30 second-1minute then goes away completelty
Old Oct 6, 2013 | 09:28 PM
mgtkr1's Avatar
mgtkr1
anyone else had this problem?
Vincereese
Jun 1, 2023 09:14 AM
Chas
Sep 21, 2015 08:57 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
dlwarrior
Aug 5, 2015 10:19 AM
