Sparking on No.4 only - cosworth management
Old Mar 21, 2005 | 10:10 AM
Austin16v's Avatar
Austin16v
Default Sparking on No.4 only - cosworth management
Hi
To fill you in, We have a 1.9 rst with cosworth management. We’re running a hybrid dizzy, cossie TB, 1.8 bottom pulley with 4 teeth at 90/180/270/360degrees a modified 1.8 sensor bracket with cossie Crank sensor, cossie water and air temp sensors.
All is now hooked up, but we only have a spark on number 4 cylinder. Using a test light on each injector plug, it seems that only number 4 injector is pulsing also.
Any ideas on what we should be looking for?
Cheers all!
Old Mar 21, 2005 | 10:22 AM
RS500/364's Avatar
RS500/364
i had it was the ECU
lucky i had a spare !!!!!!!
Old Mar 21, 2005 | 10:28 AM
Austin16v's Avatar
Austin16v
Interesting.
We've got an L1 on it at the mo, which came off of a working car. Although this will be changed for 2wd saff item with active spark and boost board in it, we have been informed that the L1 will get it started for the moment until an we find a 2wd saph item.
Maybe we should be looking for a new one now then....
thanks for your input!
jay030787
Sep 18, 2015 07:34 PM
jay030787
Aug 17, 2015 06:16 PM
Aug 14, 2015 07:29 AM
adriansaleem
Aug 1, 2015 09:28 PM
Old ford
Jul 31, 2015 06:50 AM
