Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Focus remote buttons not working
Old Sep 30, 2013 | 11:03 AM
rossosull's Avatar
rossosull
Default Focus remote buttons not working
Hi all, the remote locking buttons on my 56 Focus have packed up working. I have tried changing the battery but this has not solved the problem, which makes me think the problem is with the car.
Anyone know where the remote signal receiver box is located and if this is likely to be faulty?
Cheers in advance
Ross
Old Sep 30, 2013 | 11:11 AM
RichieST's Avatar
RichieST
They can loose their program, has happened to me a few times, it's quite simple to re-program.
Radio Frequency Programming Instructions:
  • Insert the ignition key and turn from position II (Ignition) to position 0 (All off) and back four times within three seconds.
  • Remove the ignition key. The locking control system is now in "learn mode" for the next 20 seconds and the red warning system LED (By the clock) stays on continuously to indicate this.
  • During the 20 seconds press one of the transmitter buttons. The remotes signal and code number is learned by the locking module and is indicated by flashing the warning system LED.
  • Wait until learn mode times out (20 seconds) or switch the ignition back to ON.
Old Sep 30, 2013 | 12:12 PM
rossosull's Avatar
rossosull
Hi mate thanks for the advice, just tried this and doesn't seem to be working. The car is beeping when i turn the key but nothing happens when i press the button.
Old Sep 30, 2013 | 12:23 PM
RichieST's Avatar
RichieST
Do you have another remote to try?
Old Sep 30, 2013 | 04:57 PM
GVK.'s Avatar
GVK.
Sounds like the remote itself needs testing/replacing.
Old Oct 1, 2013 | 10:29 AM
rossosull's Avatar
rossosull
Thanks for all the advice guys. After trying a new battery and reprogramming with no success the only choice was to get a new remote key.
The programming instructions are a little different to the ones posted earlier here. I found some good instructions from this replacement ford key company
I got a new remote from my local Ford dealer and programmed using these instructions, very easy
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
