Escort Cosworth WRC Fully Active (Breaking)
Old Sep 27, 2013 | 04:58 PM
MT-Motorsport's Avatar
MT-Motorsport
Default Escort Cosworth WRC Fully Active (Breaking)
New body shell caged and prepared by Gordon Vincent
Julian Godfrey WRC spec Cosworth engine- 340bhp and 522ft/lb - 30 kmh testing
New IHI WRC turbo fitted- 30kmh test
Extrac 6 speed gbox- 300kmh- new oil pump and rear housing bearings fitted- 30 kmh test
Clutch assy- 200 kmh
Front diff- 30 kmh
Centre diff- 300 kmh
Rear 9 inch diff- 300kmh
Car been fitted with all new lower control arms and rose joints front and rear-gravel and tarmac
Reiger BV rebuilt tarmac suspension- 300 kmh
Comprehensive spares package included.
Spares List for the WRC Ford Escort
1 intercooler
1 complete steering rack
2 rack end and rod ends- tarmac
3 spare steering rack boots
2 inboard gravel rod ends-inner
4 gravel rod ends-outer
Spare track rod
4 bearing housings-front
4 bearing housings -top plate
2 steering arms-tarmac left and right
1 Front anti rollbar-tarmac
1 front anti rollbar-gravel
2 front compression struts-tarmac
2 rear drop links-gravel
1 engine oil pump
2 water pumps
1 used AP Racing clutch pack
2 front tarmac discs with bells
2 rear tarmac disc with bells
3 master cylinders-.7mm
1 box of Extract Gbox oil pump gears, shafts and 2 drop gears
2 tarmac front callipers-Brembo 8 pot
1 tarmac rear calliper-AP 4 pot
2 sets of rear brake pads
1 set of front brake pads
2 cross shafts
3 front gravel driveshafts
6 front tarmac driveshafts
6 gravel rear driveshafts
1 intermediary shaft bearing assy
1 front prop shaft
1 rear section sliding prop shaft
6 rear driveshaft boots
5 rear driveshaft cv joints
1 complete set of rear Reiger gravel setup including lower control arms and mounting brackets
1 complete set of front Reiger gravel setup including lower control arms, driveshafts,compression struts, callipers, mounting plates and steering arms.
1 alternator
1starting motor
1 driveshaft tool socket
Complete set of droop spacers
1 intercooler spray pump
1 box of assorted bearings,rose joints and universal joints
1 complete lamp pod with PIAA lights
2 oil filters
1 Bosch fuel pump
1 Extract clutch release bearing seal kit
2 seal kits for MPC pump
1 egt sensor
1 set of manifold exhaust gaskets with studs
1 set of HKS spark plugs
2 timing belts
1 fuel pressure sender
1 fuel pressure regulator
2 sets of plug wires
1 drive belt
1 coolant temperature sender and adapter plate
1 coil pack
2 wheel speed sensors
1 water pump windshield wash
1 timing belt tensioner pulley
2 active diff solenoid valves
1 spare turbo housing
19 wheels 18x8 tarmac
14 wheels 15x7 gravel
1 gravel sumpguard
1 tarmac sumpguard
1 windshield
2 doors
1 bonnet
2 headlamp housing left
2 headlamp housing right
1 genuine WRC front cross member
2 gravel uprights
2 Reiger spring platforms
1 complete set of Dynamic tarmac suspension with uprights
Assort of Dynamic inserts front and rear
2 rear Dynamic upright and damper
6 gravel steering arms
1 wrc rear spoiler
2 side skirt moulds
1 wrc front bumper mould
1 gravel front bumper
1 rear bumper spare
4 complete rear headlights
2 front grills
1 roof vent assy
1 left fender spare
1 right fender spare
All Parts Available
Old Sep 27, 2013 | 04:59 PM
MT-Motorsport
Old Sep 27, 2013 | 05:00 PM
MT-Motorsport
MT-Motorsport
Old Sep 27, 2013 | 05:01 PM
MT-Motorsport
MT-Motorsport
MT-Motorsport
Old Sep 27, 2013 | 05:02 PM
MT-Motorsport
MT-Motorsport
Old Sep 27, 2013 | 05:38 PM
fordrallycar's Avatar
fordrallycar
Price on the door cards please mate
Old Sep 27, 2013 | 09:02 PM
neo's Avatar
neo
Is the fuel tank a bag tank and alloy skin ??
price on the tank as above is it internal pumps etc ??
Whats the carbon tank on the front of the fuel tank ??
Old Sep 27, 2013 | 11:41 PM
jonfoc's Avatar
jonfoc
I think the carbon tank is for water injection and intercoolers spray. Might be wrong though
Old Sep 28, 2013 | 06:47 AM
Wow thats mint.
Old Sep 28, 2013 | 07:47 AM
MikeR's Avatar
MikeR
Out of pure interest what would a car like this cost to buy?
Mike
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
