FAO people with a 6 degree rear beam
Do the spherical bearings/uniballs on your beam also make a creaking noise? Mine should be self lubricating, but that doesn't seem to work well. If put some grease between the ball joint, after which the noise is gone, but it comes back in quite a short while. I guess it's pushing the grease out again because of the force on the ball joint.
Am I using the wrong grease, or the wrong ball joints? Or should it not turn on the ball joint, but on the sleeve going through the ball joint?
it sounds like there shot ,a good joint will have a liner in them not metal to metal
mark
They are brand new from McGill Motorsport, the ultra high performance type.
http://www.mcgillmotorsport.com/m22-...rformance-113/
Oct 9, 2015 07:38 PM
155lee
Sep 14, 2015 07:37 PM
atm
Sep 1, 2015 04:56 PM
