Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
heater problem ford focus 2000
Old Sep 19, 2013 | 11:44 AM
tonyth's Avatar
tonyth
Default heater problem ford focus 2000
help, similar problem to the only working on setting 4 ones but my heater works on all four settings then after about a minute it gradually fades to nothing. If i forget to turn the switch back to 0 then i get a strange noise (humming like) from under the dashboard which goes when i return switch to 0.... I can turn fans on and before it fades turn off for a min or so then back on and works ok but a nightmare to try and warm car...any ideas??
Old Sep 19, 2013 | 11:53 AM
RichieST's Avatar
RichieST
Sounds like the blower motor bearings have failed. After they have been spinning for a bit they heat up and seize.
Old Sep 19, 2013 | 06:29 PM
Like Richie said.
Old Sep 25, 2013 | 09:20 AM
tonyth's Avatar
tonyth
Cheer Richie, out she come then!!!
taylora1409
Aug 12, 2015 12:06 PM
