Different Types of Speedo Cable?
Old Sep 14, 2013 | 07:34 PM
JSeaman's Avatar
JSeaman
Default Different Types of Speedo Cable?
I'm having a bit of a problem with a replacement speedo cable - it is a T5 gearbox from a Sierra Cosworth but is going to an aftermarket speedo (it's in a Fisher Fury kit car), mine is a metal surround like these:
http://www.ebay.co.uk/itm/SIERRA-SAP...item3cd3db08f6
http://www.ebay.co.uk/itm/Speedo-Cab...61252385014%26
The part I have received is like this:
http://www.ebay.co.uk/itm/FORD-SIERR...item45f5ea0b83
The OD is pretty much identical to the socket on the speedometer itself and therefore won't fit.
Some digging indicates it may be a standard Sierra cable rather than a Cosworth but I'm not entirely sure? Does anyone know more than me about this?
Thanks
James
Old Sep 14, 2013 | 07:41 PM
Cossy Mike's Avatar
Cossy Mike
Thanks
James
The one you have received in the diagram is for 4wd MT75 box saph/escort Cosworth
Old Sep 14, 2013 | 07:51 PM
JSeaman's Avatar
JSeaman
I see, thanks a lot. The one I bought was this:
Which looks correct - so that pic is for a T5 and the plastic ones with the click are for an MT75. Odd that the gearbox end isn't the bit that changed even though the gearbox governs the type!
Old Sep 14, 2013 | 07:54 PM
Cossy Mike's Avatar
Cossy Mike
If you mean the speedometer end it will fit although they look totally different they do work
Old Sep 14, 2013 | 08:21 PM
JSeaman's Avatar
JSeaman
Yes indeed I mean the speedo end, at the end of the day I guess the spinny bit just connects to the other spinny bit by whatever means (if we're getting technical ) - Thanks for the info
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
muz
Sep 30, 2015 08:29 AM
Johnny Knoxville
Sep 30, 2015 07:21 AM
