2.0 xr4x4 diffs in a cossie ?
Old Sep 14, 2013 | 07:55 AM
james kiely's Avatar
james kiely
Default 2.0 xr4x4 diffs in a cossie ?
has anyone ever fitted the diffs from a 2.0 xr4x4 into their 4wd saff or escos to take advantage of the 3.92 diff ratios?
is it just a staright swap ?
any info appreciated guys
Old Sep 14, 2013 | 06:16 PM
james kiely
up for the sat night crew
Old Sep 14, 2013 | 06:32 PM
PAUL S's Avatar
PAUL S
Yep straight swap James, sold some to a guy a while back that came off a ghia estate I had for the exact conversion. I have heard that they are not a strong as cossie diffs but cannot see why as they are limited slippers on the rear and normal open on the front same as a cos, just a different teeth count
Old Sep 14, 2013 | 06:48 PM
james kiely
cheers paul ,appreciate that mate
Old Sep 14, 2013 | 07:12 PM
dojj's Avatar
dojj
Resident Wrestling Legend
same fitment as the cossie, just a different ratio, 3.92:1 instead of 3.62:1 so you get better launching off the line and acceleration at the expense of top end
Old Sep 14, 2013 | 07:23 PM
Jay,'s Avatar
Jay,
Sponsor
Dojj is the 3.9 better on the mt75 box though ?
Old Sep 14, 2013 | 08:28 PM
james kiely
cheers dojj ,
i have just got a xr4x4 that will be broke [rotten]so info appreciated
Old Sep 14, 2013 | 08:31 PM
KSA-Cossie's Avatar
KSA-Cossie
Interesting, I know off a C reg xr4x4 due to be broken
Old Sep 14, 2013 | 10:57 PM
The Youth.'s Avatar
The Youth.
Be careful it's must be the 2.0 xr4x4 not the v6
I have a 3.9 rear in my race car with drop gears in the box using a standard 3.6 front diff as the 3.9 front diff is known to be weak when putting medium to big power through it, due to the physical size of the teeth which are small to squeeze more in!
Steve
Old Sep 15, 2013 | 08:53 AM
St3V3_C's Avatar
St3V3_C
As above, some of these are the same ratio as standard cos ones, so make sure you get the right one.
Old Sep 15, 2013 | 09:11 AM
dojj's Avatar
dojj
The box will give up before the diffs jay
But as ever, abuse will kill everything
You do feel the effects of the different ratios but it just means that you can get into the power quicker
In the real world I had at least twice the power with 362 diffs in my estate but the 392 CSR was only fractionally slower round the twisties, 3 or 4 mph isn't an awful lot when you are hanging it off the limiter in 2nd
Old Sep 15, 2013 | 09:13 AM
dojj's Avatar
dojj
And these riffs only came on the 2.0 dohc 4x4 sierra and the 2.8 front diff won't fit the cossie sump properly as they have a different casting
Prickly_buzz
Dec 7, 2017 09:52 PM
nico12
Dec 31, 2015 04:42 PM
mark r
Sep 29, 2015 07:27 PM
IainRS1700T
Sep 25, 2015 06:44 AM
BENJAMIN_21
Ford Fiesta
Sep 17, 2015 08:58 AM
