OZ superleggera's...saph 4wd and AP's
Old Mar 20, 2005 | 05:46 PM
wimwerf's Avatar
wimwerf
Default OZ superleggera's...saph 4wd and AP's
like subject...
are there saphs 4wd with these rims (17inch) and also have AP brakes behind them...
if yes...whats the size of these rims (17x... ET?)
if not....do they fit or not with these kind of brakes...
thanks for the help
wim
Old Mar 20, 2005 | 06:58 PM
wimwerf's Avatar
wimwerf
upski....
Old Mar 21, 2005 | 10:37 AM
Neil S's Avatar
Neil S
I'm interested in this too - I have a set of AP's but cant find any wheels (other than MO's) that fit
Neil.
Old Mar 21, 2005 | 11:20 AM
Smit's Avatar
Smit
The 60ft Launch King
Ap 4 pots with 330mm discs will fit behind 17" Super turismos i've been told.
Old Mar 21, 2005 | 11:32 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Smit,
Not on a 4x4 without spacers they don't . They do on the TSW equivalents, but they don't make them any more .
Old Mar 21, 2005 | 11:47 AM
Smit's Avatar
Smit
Got a list of wheels that will fit them brakes behind them?
Old Mar 21, 2005 | 12:00 PM
Mike Rainbird
Caraholic
MOs or MOs
Old Mar 21, 2005 | 12:02 PM
Smit's Avatar
Smit
nice selection then.
Old Mar 21, 2005 | 12:11 PM
Neil S's Avatar
Neil S
Or TH2's
Or Potentially, the Compomotive RS Focus style rims
And thats all
Neil.
Old Mar 21, 2005 | 12:32 PM
Mike Rainbird
Caraholic
I'll put a post up and see if we can get some helpful people to post .
Old Mar 21, 2005 | 12:35 PM
cossiestu's Avatar
cossiestu
MOs or MOs
I had to use a 3mm spacer under my MO's, as the caliper just clipped the spoke...
Old Mar 21, 2005 | 12:39 PM
wimwerf's Avatar
wimwerf
Originally Posted by cossiestu
MOs or MOs
is it....most MO will fit staight on with big calipers....
Old Mar 21, 2005 | 12:44 PM
cossiestu's Avatar
cossiestu
MOs or MOs
It was only a little bit, but thought it would better to fit a spacer, rather than get mr angle grinder out! Yee-ha...!
Old Mar 21, 2005 | 12:51 PM
Mike Rainbird
Caraholic
Stu,
If the brackets and bells are to the correct offset, these should fit with even ET38 wheels, let alone your ET35s which should give even more clearance . Where did your brake kit originate from?
Old Mar 21, 2005 | 12:55 PM
cossiestu's Avatar
cossiestu
Stu,
Got them from Jon Foz, they are CP6600 calipers, which may be different in size somehow...? They fit ok now and work fine!
Old Mar 21, 2005 | 02:17 PM
wimwerf's Avatar
wimwerf
Stu,
so if i understand it right...ET37 give more clearance then ET38...
Old Mar 21, 2005 | 03:28 PM
Mike Rainbird
Caraholic
Stu,
That would explain it, I'm talking about the CP5200 calliper kit. The physical dimensions are slightly different .
Wim,
Yes that is correct, the lower the number, the further the wheels stick out of the arches, so in your example with identical wheels, you would have 1mm better clearance of brakes, but 1mm worse clearance of the outer arch .
Old Mar 21, 2005 | 03:32 PM
cossiestu's Avatar
cossiestu
Stu,
Ah-Ha! I see...
Did you get my cheque by the way??
Old Mar 21, 2005 | 03:44 PM
Mike Rainbird
Caraholic
Yes, wheel ordered - expect a 4-5 delivery time though, as they shut-down over Easter for 1 week (but then again so do I ).
Old Mar 21, 2005 | 03:48 PM
cossiestu's Avatar
cossiestu
4-5 What??
Old Mar 21, 2005 | 03:51 PM
Mike Rainbird
Caraholic
weeks
Old Mar 21, 2005 | 03:58 PM
cossiestu's Avatar
cossiestu
weeks
Not a prob, i have a can of tire moose in the car, just in case...
Old Mar 21, 2005 | 04:48 PM
JamesG's Avatar
JamesG
They fit behind 8x17 TSW Imola's.
Old Mar 21, 2005 | 08:42 PM
wimwerf's Avatar
wimwerf
but they arent for sale anymore...
Old Mar 22, 2005 | 01:11 AM
Smit's Avatar
Smit
4-5 weeks???? think yaself lucky i waited fookin months
dojj
28
Sep 11, 2015 10:00 PM
focus2351
Sep 9, 2015 09:33 PM
Ridgey
Aug 30, 2015 08:37 AM
lockie
Jul 31, 2015 10:03 PM
