escort 1.8 zetec turbo. Do i need lamda sensor
Old Sep 11, 2013 | 02:08 PM
i_parker's Avatar
i_parker
Default escort 1.8 zetec turbo. Do i need lamda sensor
im in the process of building my escort 1.8 escort zetec turbo, basicly the spec is erst turbo t3 and manifold, decompression plate, 2 st170 head gaskets, standard inlet ( got to get frst rail and injectors ) OFAB ecu and loom, my question s amongst others is do I need to put lamda in the down pipe if so can I re use the escort 1.8 one
Old Sep 11, 2013 | 02:19 PM
Ben26's Avatar
Ben26
No, as the OFAB will not need one
Old Sep 11, 2013 | 05:08 PM
i_parker's Avatar
i_parker
Thanks mate
Old Sep 11, 2013 | 06:13 PM
Mk4 Rick's Avatar
Mk4 Rick
How do you get away with the emmisions on the ofab set up with having a later car that's surposed to have a lambda and cat?
Old Sep 11, 2013 | 06:14 PM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
Tell them it's pre cat engined. Is it j reg? September 92??
Old Sep 11, 2013 | 06:29 PM
i_parker's Avatar
i_parker
good question hadn't thought of this, no it's a 95 on an m plate
Old Sep 11, 2013 | 06:31 PM
SBT83's Avatar
SBT83
I'm sure it's September 92 when the law changed to have a cat. So pre 92 engine won't need checking.
Old Sep 11, 2013 | 06:38 PM
i_parker's Avatar
i_parker
ye you are right mate, I only know this as me dad had mk5 rs2000 and got a de-cat fitted with his stainless and mot's said it was fine, I was going to get some sort of cat fitted just for mot,s but abvoisley the question has risen again then would I need a lambda sensor
Old Sep 11, 2013 | 06:41 PM
SBT83's Avatar
SBT83
Do you know what year the engine is?
Old Sep 11, 2013 | 06:42 PM
Mk4 Rick's Avatar
Mk4 Rick
I wouldn't get away with fitting the ofab set up on the mk4 fiesta would I ?Then what makes me wonder is ive seen ka turbos on here with ofab set up lol
Old Sep 11, 2013 | 06:43 PM
SBT83's Avatar
SBT83
I had a decat and no lamba on my 2.0 cabby. Told em it was pre cat registered engine. They changed the emission test and it passed straight away.
Old Sep 11, 2013 | 07:05 PM
i_parker's Avatar
i_parker
What year was that on if you don't mind me asking, plus MOT laws have changed again I think
Old Sep 11, 2013 | 07:06 PM
SBT83's Avatar
SBT83
Car was M reg 95.
Old Sep 11, 2013 | 07:12 PM
i_parker's Avatar
i_parker
Sure. shorely it'd be different now i'v turbo'd it
Old Sep 11, 2013 | 07:22 PM
i_parker's Avatar
i_parker
or was your 2.0 cabby turbo aswel
Old Sep 11, 2013 | 07:46 PM
SBT83's Avatar
SBT83
No N/A 2.0. That shouldn't matter. The pre cat emissions are a higher percent carbon rate. Asking as it falls within that band it's fine. Think about every car pre 92 had to go by the same test, 1.0 - 3.0+. So I wouldn't worry bout it too much.
Old Sep 11, 2013 | 08:15 PM
i_parker's Avatar
i_parker
Thank god for that lol thanks mate for your help, im going to try an find the year of the engine if I can, would you no how to find this
Old Sep 11, 2013 | 08:19 PM
SBT83's Avatar
SBT83
There was a way that a car dealer showed me when I setup. It's to do with the little clock looking imprints. I'm sure you will have seen them on a part or 2. To get a rough Idea go on if its a silvertop or blacktop. That will narrow down to pre or post 2000 roughly
Old Sep 11, 2013 | 08:27 PM
Ben26's Avatar
Ben26
They always go with whats older. Car or the engine. In your case the engine so it has to be below 3.5 ppm i believe. But im no MOT tester
Old Sep 11, 2013 | 08:30 PM
SBT83's Avatar
SBT83
You may get a dodgy tester, not that I condone that sort of thing
Old Sep 11, 2013 | 08:34 PM
Mk4 Rick's Avatar
Mk4 Rick
Ive got no chance on my mk4 fiesta then lol ive got a 2litre blacktop in mine lol
Old Sep 11, 2013 | 08:36 PM
SBT83's Avatar
SBT83
Doesn't matter. You could have changed the rocker cover. The blacktop is more likely to be easier on emissions as its slightly newer. Font quote me but in theory the newer and lesser wear should do you a favour
Old Sep 11, 2013 | 09:01 PM
i_parker's Avatar
i_parker
Mines the silver top it's the same engine that's stayed with the car' bit worried now
Old Sep 11, 2013 | 09:10 PM
SBT83's Avatar
SBT83
Be fine mate! Just tell em it's pre cat engine. They'll put it on accordingly
Old Sep 11, 2013 | 09:13 PM
i_parker's Avatar
i_parker
sweet im happy with that, so no need to worry about cat then, what if they start saying " ye mate but it's after a j reg "
Old Sep 11, 2013 | 09:18 PM
SBT83's Avatar
SBT83
Your engines not though is it don't have to fit a cat to it so that's that :Ł
Old Sep 11, 2013 | 09:38 PM
i_parker's Avatar
i_parker
Sorry mate what do you mean ?
Old Sep 11, 2013 | 09:42 PM
SBT83's Avatar
SBT83
Your engines not after 92 is it?!!! Wink wink
Old Sep 11, 2013 | 09:50 PM
i_parker's Avatar
i_parker
sorry mate, LOL, just read that first bit again after putting "what do you mean" lol makes perfect sense LOL, sorry, having abit of a girl moment there lol, well im hoping it'll be ok as it'll make my life easier to just to get escort rs turbo stainless downpipe and just modifiy it to fit my mk5 rs2000 mongoose that already has de-cat fited to it, stole it off me dad lol not that he cared bless him
Old Sep 11, 2013 | 09:54 PM
SBT83's Avatar
SBT83
Top bloke!! When mines built and I get a little puma to stick it in, ill be making my own stainless exhaust. I'm not too handy with a mig but my dad used to weld manifolds for different race event teams so he can weld shit hot lol. Get a few tips off him.
Old Sep 11, 2013 | 09:57 PM
i_parker's Avatar
i_parker
do you fancy doing 2 instead LOL
Old Sep 11, 2013 | 10:00 PM
SBT83's Avatar
SBT83
Lol see how one turns out first. Amateur springs to mind
Old Sep 11, 2013 | 10:06 PM
i_parker's Avatar
i_parker
at least your giving it ago, I,d proberly weld spatters every where lol
Old Sep 11, 2013 | 10:13 PM
SBT83's Avatar
SBT83
Yeah it's all about having a crack at it! Just jump in the deep end I say
Old Sep 11, 2013 | 10:22 PM
i_parker's Avatar
i_parker
are you building a zetec turbo, if so what ecu and inlet you useing
Old Sep 11, 2013 | 10:25 PM
SBT83's Avatar
SBT83
Yep, rover turbo inlet with cossie tb, area six ex mani.
Gonna go megasquirt to save money in the long run
Old Sep 11, 2013 | 10:39 PM
i_parker's Avatar
i_parker
mines a baby compared to yours, with out sounding a tight sod lol, when I looked into doing this I saw a lot of people saying how cheap they built a budget build, well im sort of on the mission to get it as cheaper than them but as long as its got proper ford items new in same cases coz want it done properly lol, I take it you,l be sending it off to get wired up
Old Sep 11, 2013 | 11:36 PM
SBT83's Avatar
SBT83
Nope do it myself. Easy. Done it loads
Old Sep 11, 2013 | 11:39 PM
i_parker's Avatar
i_parker
Christ your joking lol, im having trouble how to wire up the ofab loom o my 1.8 loom, no one can give me a straight answer lol
Old Sep 11, 2013 | 11:40 PM
SBT83's Avatar
SBT83
It's easier to see it in the flesh and have some time with it
