2002 ford escort 55 van diesel knock
Old Sep 7, 2013 | 09:29 PM
scorpion18's Avatar
scorpion18
Default 2002 ford escort 55 van diesel knock
Hi was wondering if anybody can help I own a 2002 ford escort van 1.8 non turbo
My mate who is a professional mechanic recently replaced the timing belt and the other belt that gets changed at the time he used all the proper tools for the job locked of pumps and set timing perfect after changing belt however after building the engine back up and starting it the engine has became very noisy like an knocking noise . My friend said this is a disel knock but he has no idea how to fix it . This is where yous come in can any one help to explain how to fix this . The van was running perfectly before work was done
Old Sep 7, 2013 | 09:33 PM
gup's Avatar
gup
Does it smoke
Did he adjust the fuel pump to take the slack from the belt
Try to put the pump back where the old marks where
If that makes sense
Old Sep 7, 2013 | 10:51 PM
botters's Avatar
botters
competant bodger
i would double check the timing if it wasnt there before the belt but is there now it can only be timing
Old Sep 8, 2013 | 12:07 AM
scorpion18's Avatar
scorpion18
The timing is perfect he striped and checked it . Yeah its really smoking he oocked the pump of while doing the belt . Do you think it could have moved when tensioning the belt.
Old Sep 8, 2013 | 07:19 AM
gup's Avatar
gup
Yes try and move the pump pulley back to the original marks where the bolts made a mark
And try that
If this make sense
Old Sep 8, 2013 | 10:45 AM
saph4be's Avatar
saph4be
I believe they have a advance solenoid on the diesel pump which can so e how be affected by changing the belts! I had it years ago and put a new solenoid in and was fine after! I did get told the reason why but it escaped me know as it was a long time ago
Old Sep 8, 2013 | 11:01 AM
jamie's's Avatar
jamie's
sounds like the pump advances, try knocking it back a little and see if that helps
Old Sep 8, 2013 | 11:04 AM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Thousand percent he's disturebed the pump timing. Mates dad years ago used to buy lots of these at auction as people thought the engine was fucked etc etc. everyone was the timing on pump was out.
matman
Sep 9, 2015 05:45 PM
dodge8283
27
Aug 19, 2015 08:42 AM
druidgetafix
Aug 15, 2015 10:22 AM
