Just got a set of Mondeo calipers
Old Sep 5, 2013 | 06:27 PM
theheap's Avatar
theheap
Default Just got a set of Mondeo calipers
Evening all. I have spent a couple of quid on these mk3 jobbies and I am now looking for these spacers I keep reading about.
What am I actually spacing?
Where are they available?
I have some sheet metal so if not available does anyone know for sure the mm I need so I can make them?
Thank you
Terry
Old Sep 5, 2013 | 06:45 PM
Gadget's Avatar
Gadget
Spanner monkey
Thank you
Terry
You want a 12mm spacer between the caliper and hub mate, will also need to drill the holes in the hub to 12mm to accept the bigger m12 mondeo bolt.
You can get the kit on e bay cheap.
Old Sep 5, 2013 | 07:31 PM
theheap's Avatar
theheap
12mm?! Karaoke man I thought it was about 4mm.
eBay it is then
Old Sep 5, 2013 | 11:06 PM
foci18's Avatar
foci18
Any chance if you do find the kit could you put a link up as I'm trying to do the same conversion cheers pal
Old Sep 6, 2013 | 08:18 AM
luke19790_3's Avatar
luke19790_3
I've got a set at home
Old Sep 6, 2013 | 08:42 AM
theheap's Avatar
theheap
Luke you talking spacers? If so let me know how much or where you got them please.
Terry
Old Sep 6, 2013 | 09:50 PM
B19 JUB's Avatar
B19 JUB
theres a guy on ebay who sells spacers for brembos.i emailed him and he has his engineer make me up said spacers.tbh I had 12mm ones made but carriers still touched the disc so put a 1mm washer in and was spaced perfect.
http://www.ebay.co.uk/itm/Brake-Cali...item337fd3f998
obv sells them now
Old Sep 7, 2013 | 08:31 AM
theheap's Avatar
theheap
Thank you mr jub. Now all I need are the discs. St170 jobbies?
Also what about the hoses, can I use my originals?
Old Sep 7, 2013 | 08:38 PM
B19 JUB's Avatar
B19 JUB
yeah st170 discs.i got mtech ones on my orion and they are great.some like them some hate them.
hose wise I got a set of braided from matt lewis and believe ive got adaptors as original pipes have a female connection on them and so do the braided ones
Old Sep 9, 2013 | 08:43 AM
theheap's Avatar
theheap
Cool mate. I'll get the spacers bolts and discs then look for the pipes
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
yatta
May 21, 2016 10:31 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
cossirob
Sep 3, 2015 09:17 PM
turbowag
Sep 3, 2015 08:07 AM
