Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
engine light
Old Sep 1, 2013 | 06:59 AM
ianm2585's Avatar
ianm2585
Default engine light
getting to the last bits on my fiesta now one i am not overly concerned about is the engine light which is not working even on the test with the trip switch. i have various wiring diagrams but if someone put this light out intentionally where would be the best place to cut a wire or remove a fuse.i was going to start at the ecu end i have the pin number for the light (somewhere) then look at the dashboard end .problems arise after this as i have no wiring diagrams that show connector blocks inbetween the two.Its 1.25 zetec 2000 and this is the last thing not working so would like to try and fix if possible also have it working incase it does become a mot test item
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Bailes1992
Aug 16, 2015 07:14 PM
taylora1409
Aug 12, 2015 12:06 PM
Old ford
Jul 31, 2015 06:50 AM
