Mk7 escort 1.6 cutting out
Old Aug 30, 2013 | 09:42 PM
wedge07's Avatar
wedge07
Default Mk7 escort 1.6 cutting out
Hi my friends escort keeps cutting out when slowing down to stop, I changed maf sensor on it as it wasn't as bad when unplugged but when we put new one on it was same as before.
The revs are always really low and hunting.
I thought it could of been the idle speed valve is knackered but do they have a maf AND iscv? As I never saw iscv on a quick look.
Any help would be appreciated thanks
Old Aug 30, 2013 | 09:57 PM
matts1's Avatar
matts1
is this like the focus issue, speed sensor?
Old Aug 30, 2013 | 10:02 PM
wedge07's Avatar
wedge07
He says it is crap in mornings too but not as bad when it's been being used. If you get me?
Old Aug 30, 2013 | 11:10 PM
viperz888's Avatar
viperz888
Idle control valve almost 100%. Notorious on that engine, the good news is you probably can get away with just cleaning it with brake cleaner or petrol, rarely do you actually need a new part.
Old Aug 30, 2013 | 11:33 PM
GVK.'s Avatar
GVK.
It's under the manifold below the throttle body. (ISCV) 2x8mm bolts hold it on.
Check for air leaks too, if disconnecting the MAF makes it run better.
Old Aug 31, 2013 | 09:43 AM
wedge07's Avatar
wedge07
So it defo has both? Lol
Old Aug 31, 2013 | 10:29 AM
viperz888's Avatar
viperz888
Yeah, zetecs have both, I've never heard of a maf going on one though.
Some engines have them on the top of the manifold, on the left.
If you put up a pic of the engine, I'll show you where it is.
Old Aug 31, 2013 | 01:43 PM
GVK.'s Avatar
GVK.
It'll be like this -
If you remove the throttle body (only 4 bolts), it's easier to see/undo the top bolt on the ISCV, as it's under the manifold directly under the throttle body, the other bolt needs to be done from underneath. Watch the seal, easy to get it on the piss if it's not sitting in the groove on the intake correctly. Get an 8mm ratchet spanner! Clean the throttle body where the throttle plate sits too.
If removing the maf plug makes it run better but a new maf doesn't fix it check for air leaks/vac pipes/servo pipe/servo itself/intake gaskets Also, on the intake hose there's an intake air sensor, with engine movement the wires can get snapped off. Check that too.
On some zetec they have a vac hose under the coil pack that splits too,worth a look.
Old Aug 31, 2013 | 01:49 PM
GVK.'s Avatar
GVK.
You'll see why when you find it.
Old Sep 1, 2013 | 10:03 AM
Oranoco's Avatar
Oranoco
It'll be a Mk6 Escort as there is no such thing as a mk7 despite what some say and catalogues list
Old Sep 1, 2013 | 03:04 PM
GVK.'s Avatar
GVK.
I don't go by MK anything other than on old stuff.
But if I posted a 95 MY Escort, people would go "What?"
Ford call the models by their model year when introduced.
Not by MK anything!
End of rant
Old Sep 1, 2013 | 03:17 PM
wedge07's Avatar
wedge07
Lol I ain't bothered about it being a mo7 6 5 or even 20 I just want to find the problem oranoco
And he ain't been down yet gvk so as soon as he's down again ill let you know bud. Fingers crossed it is just that
Old Sep 1, 2013 | 03:56 PM
cabriolet's Avatar
cabriolet
iscv what a pig to put back i wish you luck
Old Sep 1, 2013 | 04:59 PM
GVK.'s Avatar
GVK.
LOL, here speaks a man of experience!
Old Sep 1, 2013 | 05:03 PM
wedge07's Avatar
wedge07
Great I'm gonna have lots of fun by sounds of it! Lol
Old Sep 1, 2013 | 09:56 PM
Oranoco's Avatar
Oranoco
You might not be bothered but getting it right will make somebody being able to diagnose it for you more likely.
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
