Need feedback on my own spec
Afternoon everyone
Just looking for opinions on a spec I've been thinking about using in my new project.
If you think I've got things missing or too ott etc then please let me know.
The end result I'm hoping for is around 480-500bhp.
Neil roper 500bhp spec head
BD 14 inlet cam
BD ?? Exhaust cam
Standard exhaust cam
Escos Small Turbo inlet plenum cover
Wrc head gasket
Standard crank , rods and pocketed pistons
200 block, 6 studded
2wd exhaust manifold
Siemens 83lb injectors
GT3076 turbo
Tial 38mm external wastegate
Air injectors
3" exhaust system
RS500 alloy cooler
L8 Mapped by ?????
Hope to get some good feedback
Thanks in advance
BD 14 inlet cam
BD ?? Exhaust cam
Wrc head gasket
GT3076 turbo
Air injectors
3" exhaust system
RS500 alloy cooler
L8 Mapped by ?????
Thanks in advance
BD14 as an example, but you really need to get the person who is mapping it to spec the cams as most have their own spec. Dont waste money on parts on the say so of people on the internet, pick a mapper and speak to them about the spec
a AB07 is only used if you dont have valve pockets in the pistons and its a good alternative, but as you are building from scratch you can get the pistons pocketed and therefore use a cam more suited to what you want to achieve
Makes sense.
Also please don't think I'm going to build an engine purely from what people on the Internet say
Just want opinions and ideas... Keeping an open mind about it.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
aka Turbosailorboy
Diff and box will be addressed at a later date and I should have space for a decent cooler. By that do you mean something like the spec r one?
aka Turbosailorboy
Also your choice of external wastegate will make it difficult on trackdays if you dont plumb it back into main exhaust.....but screamers are
It means unlimited dB noise days only.
Rich
