Siemens 83lb injectors..... Where?
Old Aug 30, 2013 | 09:16 AM
Billy_RS's Avatar
Billy_RS
Default Siemens 83lb injectors..... Where?
Does anyone stock these anymore?
Proving alot harder to find then i first thought!
Billy
Old Aug 30, 2013 | 01:39 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
I'm sure I read somewhere you can't buy them new any more?
Old Aug 30, 2013 | 04:44 PM
a-mac's Avatar
a-mac
are you not going to be running omex management, if so you can use different
injectors as siemens are low imp and will need resistors to work , you could run
high imp injectors that will be easier to get hold off
Old Aug 30, 2013 | 05:17 PM
delbee1's Avatar
delbee1
Billy
Turbosystems may still have some, MSD were working on an alternative, Lucus I think, but not sure how that panned out
As above really, if your using after market ECU check which imp injectors you need before you buy them
Nov 1, 2015 06:53 PM
Danielbetty
Oct 3, 2015 06:01 PM
timsrs
22
Sep 24, 2015 08:14 PM
cos elle
Sep 16, 2015 06:37 PM
trevCOSS
Aug 4, 2007 09:00 AM
