HID Kit in a Projector headlamp?
Evening all
Just looking for a bit of info really for installing a HID kit into a projector lamp. A few years ago I fitted a kit into an old Focus with a normal headlamp and they were dazzling and had no beam pattern.
I have heard that a projector lamp will not cause any dazzle and will have a perfect beam pattern. Is this the case?
By the way, I am FULLY aware of the legalities of aftermarket HID kits so don't need any input on that, just looking for people's experiences!
as above projector headlights are fine.
you can get hid bulbs for non projector lights as well which dont dazzle, i was sceptical but after trying them the beam pattern was spot on.
Thanks for that, another question, are the more expensive kits better than cheaper ones? I will probably need something suitable for can bus and will go for 4300k as that is supposed to be the same as an oem system.
Ł30-40 will get you a good kit
i have 8000k's and they are really good, but are a little too blue and don't look legal
i have heard 4300k is also the closest to what you would get from manufacturer
anything over 6000k starts to look tacky, 4300k or 5000k is what i'd go for.
price wise i've had a few sets and they all seem to perform the same, the Ł30 set in my van gets the same use and has lasted just as long as the Ł60 set did in my passat.
the only issue i had was the colour rating, the cheaper set looks slightly higher than the 5000k they were rated to. but it'll be like all things cheap, you pay the money and take a chance, but i reckon 9/10 times they will be fine
I just fitted a set that cost Ł26 for h1 off eBay.
I can't fault them, they work perfectly. How long they last is a different matter but so far so good.
I got 6000k as I didn't like the yellow of 4300 and over 6000 they're too blue, I'd probably go for 5000k next time.
cheers guys, pick up the new car Sunday so will get a set bought! They do a kit with slim ballasts which are supposed to fit inside the headlamp unit so might get those.
