*SOLD* XR2i Fiesta Track Car
From: Sudbury Suffolk, Drives: Octavia VRS & XR2i 1800 Zetec track car
She is a 1991 model in black with pretty all running gear from an RS1800.
MOT until July 2014
Currently SORN
Spec as follows:
Silver top 130bhp Zetec
RS turbo box and clutch
Ram air induction kit and pipework
Both lower arms replaced last year
All gearbox mounts replaced last year
Brembo front discs with yellow stuff ads 6 months old
Rear shoes and cylinders replaced
Racing brake fluid
Full magnex system 92 Db max
6 point full cage
Rear strut brace
Drivers seat sparco evo with 5 point Schroth harness
Passenger seat rs1800 3 point harness.
Battery in boot
Momo race steering wheel
Completly stripped out gripper tape in drivers footwell.
AVO adjustable coilovers.
Ally catch tank
Never uses any oil or water
Always run on Motul 300V oil
Wolfrace 15" Alloys currently with its wets on Hancook Ventus v12 evos part worn
Comes with a set of part worn Toyo R888s
Various spares
Speedo was changed by previous owner when the engine was put in, now showing
The shell is the most solid I have seen
Always garaged
Bad points:
Sunroof removed and alloy sheet put in place but badly painted by previous owner
Bonnet is sprayed satin black not best job
Few marks around car but still very presentable
Slight mark around filler cap see pics
Gearbox whines, but has since we have had her and driven to and from over 6 track days. Still goes into gear perfect.
May need a new battery sometimes needs a jump
She handles so well on track and always puts a smile on your face.
Out handles alot of more expensive machinery.
Just want her to be enjoyed as other wise will sit and not get used
Viewing welcome
£1,695
07979 806305
Aug 12, 2015 09:35 PM
