need to replace my drivers side drip rail panel . ive cut of outer wing do i need to cut the a panel below th fuse box and fit it underneath and peel th a post joint back or can i trim the new panel lip of and fit above the fuse box panel any advice or pics would be appreciated
noone ever repalced one then . most common corrosion point on an escort ?????????????????? do i sit new panel ontop of old remaining inner wing , or below
