Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Tdci 1.6 cambelt
Old Aug 16, 2013 | 10:43 PM
RS beddy's Avatar
RS beddy
Default Tdci 1.6 cambelt
Hi all I am after a bit of advice, I have a 56 reg tdci 1.6 lx focus an I am after changing the cam belt I am competent doing the job as i rebuilt my 2wd cosworth engine but I did not need a locking tool as they are fairly self explanatory if you mark them up top dead center but the focus don't look so simple an i have bin told i need a locking tool but were would it go any advice would be help full thanks
Old Aug 17, 2013 | 01:48 PM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
Triple post on the same topic must be some sort of record!! Good one for the muppet room
Old Aug 17, 2013 | 02:18 PM
BRAM's Avatar
BRAM
There is a pin goes in the cam pulley when it's at about 1 o'clock ish and there is a pin that goes in the crank pulley at 12 o'clock, you have to take the bottom pulley off first though
Old Aug 17, 2013 | 03:25 PM
RS beddy's Avatar
RS beddy
Ok thanks, do u have to lock both cams or will they stay attached to the rocker cover when it lifts off do you know? Thanks agen
Old Aug 17, 2013 | 03:31 PM
RS beddy's Avatar
RS beddy
Haha I only just downloaded the pf app an it was saying its not loaded when I was trying to post haha like a newbie agen with this phone
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
The Enigma
Sep 29, 2015 10:31 AM
mondeomark
Sep 28, 2015 06:28 AM
Sp3no
Sep 27, 2015 07:23 PM
