How can I get tree sap off of red paint?
Old Aug 16, 2013 | 06:54 PM
CalXR2's Avatar
CalXR2
Default How can I get tree sap off of red paint?
Quite a few white splodges of tree sap on the roof and bonnet which I can't get rid of atm. Does anybody know of any tried and tested home methods for removing sap?
Cheers.
Old Aug 17, 2013 | 03:26 PM
uruk hai's Avatar
uruk hai
You could try a tar and glue remover but as it's on the bonnet and roof I wouldn't spray or poor it on, I would poor a little on a rag and put it on top of the sap for no more than a few minutes. Once it's been soaked for a minute or two gently rub it with the cloth, you may need a few goes at it but it should work. Once it's off wash the area and rinse thoroughly, the problem with sap is that if left for any length of time it can end up etching the lacquer and/or paint !
Old Aug 17, 2013 | 03:50 PM
2wd saff cos @ stage 3's Avatar
clay bar?
Old Aug 18, 2013 | 09:30 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Try all the above, and you can also try soaking it with some G101 then wiping it off
All depends on what you have to hand.
Old Aug 28, 2013 | 01:33 PM
TIFF's Avatar
TIFF
Chasing Radders
As said by Al....G101 is your best bet tbh...............
Old Nov 17, 2013 | 08:18 PM
nickwrxstiv2's Avatar
nickwrxstiv2
Isopropyl Alcohol. Works unbelievably well on tree sap, cuts straight through it. It will remove your protective layer, wax or sealant, so you would have to reapply it afterwards.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
rsguy
44
Sep 29, 2015 03:29 PM
