Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
15inch Alloys onto a MK5 Fiesta fun with 13inch wheels
Old Aug 16, 2013 | 12:35 AM
Robsters's Avatar
Robsters
Default 15inch Alloys onto a MK5 Fiesta fun with 13inch wheels
I basically wanna update my ford fiesta fun to alloy zetek wheels but my current wheels are 13inch and the alloys i wanna get are 15inch, will i have any issues to just convert it? my car is 1.3 , my friend said my suspension would have to be upgraded and would use more having bigger wheels.....is this true?
thanks
Old Aug 16, 2013 | 05:15 AM
bagginsRSturbo's Avatar
bagginsRSturbo
You will be able to run 15" no probs and you won't need to change the suspension either
Old Aug 16, 2013 | 06:05 AM
STeve's Avatar
Super Moderator
you can even run 16s with correct tyre choice and no suspension change either
Old Aug 16, 2013 | 09:25 AM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
If your fitting 15's just run a 195 45 15 tyre and you'll be right as rain
Old Aug 16, 2013 | 01:01 PM
Robsters's Avatar
Robsters
Cheers guys for all your info, just one more question, would it use more fuel having bigger wheels?
Old Aug 16, 2013 | 02:00 PM
CosworthGuy
3dr Cosworth owner
If your rolling radius stays the same then not at all. Could even go as far as to say that if the new rolling radius is slightly bigger then you would cover more distance on the same amount of fuel but id safely say you would not notice a difference in the slightest
Old Aug 16, 2013 | 02:23 PM
STeve's Avatar
Super Moderator
Originally Posted by Zetec S Hayley
I put MK6 wheels on my MK5 and they are 16 inches...as mentioned choose the right tyre
mine is running 16s too in fact 205/45s
that size is more suited for mk3 fez models etc as mk5s run 50 profile as OE on mk5 zetec S
Old Aug 16, 2013 | 05:30 PM
Robsters's Avatar
Robsters
found a set zetek alloys 15inch for 80quid, think tires are quite gd to, bargain right? swap these for 13inch grandma wheels on my fiesta shud make it look a lot better, is it litrally easy as take old wheels off and pop the new ones on yeah?
Old Aug 16, 2013 | 05:43 PM
T4onYB's Avatar
T4onYB
FRS chap
Unless your 13s are alloys you will need alloy wheel nuts too
Old Aug 16, 2013 | 05:53 PM
Robsters's Avatar
Robsters
my 13s are not alloys no, my mate keeps going on that i will have problems fitting 15s on a 13inch rim? what he mean by this and is ther any truth to it? surely my fiesta mk5 shud fit 15s ok same as any fiesta would?
Old Aug 16, 2013 | 08:21 PM
STeve's Avatar
Super Moderator
no offence to your mate but he does not know what the hell he is talking about as its obvious 15" tyres wont fit on a 13" rim, but 15" tyres fit of 15" rims and whats more they fit the mk4/5 perfect as do 14/15/16 inch wheels fit fine if right offset and correct tyre size for instance, and make sure you get alloy wheel nuts to fit your car as the original steel ones are no good for alloys
14" 175/65/14
15" 195/50/15
16" 195/45/16
Old Aug 20, 2013 | 12:56 AM
Robsters's Avatar
Robsters
i think he was just jelious of idea of me getting the car looking good as little fiesta becoming a bit a classic now isnt it and with alloys they look nice!
Old Aug 20, 2013 | 09:25 AM
roose1983's Avatar
roose1983
I had 15"oz an 16" mondeo alloys on my mk3 never had any problems with either of these sets as above just make sure you get the right offset an tyres as that's where you will have issues with fouling struts or arches
steerfromdarear
28
Jan 29, 2016 06:14 PM
Alloy wheels and ICE for sale
14
Sep 26, 2015 05:40 AM
cossynut2
Aug 19, 2015 11:29 AM
Seanyfarrell
Aug 14, 2015 11:37 PM
turbobill
Aug 1, 2015 08:55 PM
