Load vavles
Old Aug 11, 2013 | 09:00 PM
Ryoishikawa's Avatar
Ryoishikawa
Default Load vavles
Can I remove the rear load valve on my s2 and just put a cooper pipe where it used to go.
Or would it cause problems with my brake setup like rear brakes taking over the fronts
Old Aug 11, 2013 | 09:03 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
yes if you remove ALL of the ABS system or it will not pass an MOT, this includes master cylinder etc
Old Aug 11, 2013 | 09:05 PM
Ryoishikawa
But the car has abs on the front only tho
Old Aug 12, 2013 | 07:45 AM
simonmcf's Avatar
simonmcf
Fit a xr3i set up instead?
tankybaby66
Feb 6, 2016 02:24 PM
mk1turboestate
Dec 2, 2015 08:31 PM
Fiddy
21
Sep 29, 2015 06:10 PM
