Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
The girlfriends 1.25 mk 4 fez, idel problem. Help please
Old Aug 5, 2013 | 10:17 PM
Cilly-jey's Avatar
Cilly-jey
Default The girlfriends 1.25 mk 4 fez, idel problem. Help please
Well the girlfriend has had this car for 4 weeks now and says it stalling when she is going slow round corners or slowing down..
Well it has never happened to me and she is happy for me to accuse her, that is just her driving and not use to the car yet.
But just wondering do the suffer form poor idling problems? And what can I check or look out for as we are ment to be using this to travel to ford fair on the weekend.
Any advice would be welcome, thank you
Also may I add it is a well serviced car with 69.000 miles on the clock.
Old Aug 5, 2013 | 10:23 PM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
I'm not really clued up on this engine but someone will tell you if it's right or not.
The idle control valve? Maybe it needs cleaning.
Like I said i don't know the set up so I'm guessing.
And it doesn't stall for you?
Old Aug 5, 2013 | 10:38 PM
Cilly-jey's Avatar
Cilly-jey
I've drove it twice to the shops and it was fine for me. But got to take her word for it as we all no they are always right lol..
Old Aug 5, 2013 | 10:41 PM
Ellis1990's Avatar
Ellis1990
mine does it, its intermediat but it used to be awful at it so i took the airflow sensor off and cleaned it, its between your filter box and your throttle.
try that see what happens.
Old Aug 5, 2013 | 10:47 PM
Cilly-jey's Avatar
Cilly-jey
Thanks m8 I will try that, if some of the bits work of my zs I might swap a few over and see what happens
Old Aug 5, 2013 | 10:53 PM
SBT83's Avatar
SBT83
Good one dude!
If it was happening all the time like my xr2i did, it was down to an air leak to the brake servo/vacuum hoses
Old Aug 5, 2013 | 11:01 PM
GVK.'s Avatar
GVK.
idle valve may need cleaning.
check breather pipes on the intake, they can split or go soft and collapse
check throttle body itself, may need cleaning.
maf as mentioned
Also the clutch pedal has a switch on make sure it's plugged in/wires are not broken.
Old Aug 6, 2013 | 05:20 AM
The wifes old fiesta did it a few times.There is a Idle Speed Control Valve on the manifold.Its held on by 2 8 mm bolts.Remove the ISCV and clean it out with brake cleaner then soak it in brake fluid over night. Then refit.
Old Aug 6, 2013 | 09:42 AM
Cilly-jey's Avatar
Cilly-jey
Thanks for your help lads..
Old Aug 7, 2013 | 08:06 AM
rsturbolee's Avatar
rsturbolee
speed sensors on these play up, same as focus etc, they hold the revs up till you come to a complete stop when faulty they stall
clutch pedal sensor plays up too
Old Aug 7, 2013 | 12:29 PM
richard youll's Avatar
richard youll
You've got a girlfriend Chris??? Wtf I'm amazed lol
I hope she doesn't look like the back end of a bus!
Old Aug 7, 2013 | 12:37 PM
mentalasanything's Avatar
mentalasanything
My wife's old Mk4 Fiesta 1.3 used to do this, her old man regularly had to clean the ISCV.
Lee
Old Aug 7, 2013 | 04:51 PM
Brendan's Avatar
Brendan
struggling with reality
This is a annotated pic of the puma engine and is very similar!
Attached Thumbnails The girlfriends 1.25 mk 4 fez, idel problem. Help please-puma-engine.jpg
Old Aug 7, 2013 | 06:55 PM
Cilly-jey's Avatar
Cilly-jey
Thanks for the kind words and some of your expert technical mechanical nohow could come in handy.
And sorry to disappoint m8 she's good looking and 21!
Old Aug 7, 2013 | 11:28 PM
SBT83's Avatar
SBT83
Pictures say a thousand words
Old Aug 8, 2013 | 08:00 AM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
This, there's a 'Y' shaped one that is the block breather, it's kind of 'in' the inlet manifold (where it curves around) and these are well know for splitting.
There's also the Power Steering Pressure sensor, it's behind the front bumper at the bottom to the right, a cylindrical sensor with a plug and 2 wires, check the wires aren't broken/damaged as this can cause the idle to be all over the place.
And as above, check the ISCV and possibly the speed sensor.
Prickly_buzz
Dec 7, 2017 09:52 PM
Fordmad!
15
Sep 27, 2015 06:24 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
CossieRich
30
Sep 8, 2015 10:08 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
