2wd rear diff
Old Aug 3, 2013 | 06:04 PM
cossiedad's Avatar
cossiedad
Default 2wd rear diff
The other night my driveshaft came off the diff drive flange. Of the 6 bolts, 2 have stripped the threads in the flange.
Can these be helicoiled safely? Or is that unwise due to the torque forces on the bolts?
Can I simply replace the flange from another diff? If so, how hard is it to do?
Any other suggestions as a quick fix as Ford Fair is only next weekend?
cheeRS
Old Aug 3, 2013 | 06:11 PM
jon@work's Avatar
jon@work
I don't think you'll have any issues if you helicoil the 2 damaged threads.
Old Aug 3, 2013 | 06:20 PM
cossie891's Avatar
cossie891
If you get stuck I have a pair of flanges sat in the shed
Old Aug 3, 2013 | 06:43 PM
cossiedad's Avatar
cossiedad
How much do you want for them? And are they a bastard to change?
cheeRS
Old Aug 3, 2013 | 06:51 PM
cossie891's Avatar
cossie891
All you do is take the rear cover off and they are held in with a like e clip they just push off and the flange pulls out
Old Aug 3, 2013 | 06:55 PM
cossiedad's Avatar
cossiedad
Can it be done with the diff in the car or does it have to come out? I know what I'm doing with spanners but just not stripped a diff before so sorry for the questions.
cheeRS
Old Aug 3, 2013 | 07:02 PM
cossie891's Avatar
cossie891
It has to come out mate won't take 20 mins to pull it out the car then it's just straight forward
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
RSBryden
Sep 6, 2015 08:39 PM
turbowag
Sep 3, 2015 08:07 AM
FlashRS
13
Aug 31, 2015 06:02 PM
xr4x4rs
Aug 6, 2015 09:03 PM
