Help re -rear axle pick up points
Old Aug 3, 2013 | 11:27 AM
2Litre's Avatar
2Litre
Default Help re -rear axle pick up points
Hi- looking for some help re pick -up mountings points for the rear axle of a 3 door. I had an accident that caused the drivers side rear trailing arm to bend tucking the wheel into the rear arch,I have replaced the trailing arm but it appears that the main mounting bolt(Through big rubber bush) on axle is off at an angle. It looks like the threaded locator insert point has moved the chassis leg looks fine.
Does anyone have any measurements from these points to other known reference points to confirm?
Sorry if this is confusing.
Thanks. Tim.
gambo08
Feb 4, 2016 10:49 PM
gcfcos
59
Oct 6, 2015 05:04 PM
