Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
aftermarket stereo connecting problem
Old Aug 1, 2013 | 08:32 PM
gadslon's Avatar
gadslon
Default aftermarket stereo connecting problem
http:// http:// Hi I have problem with connecting pioneer MOSFAT 4000UB with my stalk control adapter above are pics of all cables as u can see only 2 orange are not connected Plz Help!
Old Aug 1, 2013 | 09:09 PM
st220kyle's Avatar
st220kyle
Your new cd player may not be compatible with the stalk controls, therefore there will be nowhere to connect the Orange wires,so the stalk controls will not work.
Old Aug 1, 2013 | 09:13 PM
Smudge374's Avatar
Smudge374
Most after market stereos are not compatible with stalk controls so they may now be redundant, also if you find the stereo losing its memory after removing the keys and switching off, swap the red and yellow wires over, one is perm live and the other from ignition.
Old Aug 2, 2013 | 07:22 AM
Daniel-1986's Avatar
Daniel-1986
did the stalk kit come with the patch lead for the pioneer stereo, I had to order the sony kit (2 separate packages) for my sony stereo and works a treat
Old Aug 3, 2013 | 04:04 PM
gadslon's Avatar
gadslon
Thanx all for help it was not compatible with pioneer had to buy another one now I changed front speakers for jvc 2x280w (have to check model) they bigger and my problem is that bass sounds like is blawn or touch door when I change for only one side sound is ok but when I set both bass is rubbish . Might that be that I need amplifier?
Old Aug 3, 2013 | 04:21 PM
st220kyle's Avatar
st220kyle
Look at what the output of the cd player is, if its lower than the speaker output(which I suspect it is) you will need an amp or some speakers with a lower output.
Old Aug 3, 2013 | 05:12 PM
gadslon's Avatar
gadslon
Cd is 4x50w speakers real pow is 100w so its should be ok I have to double check wiring
S3an
Sep 26, 2015 11:39 PM
biggiejody
Sep 19, 2015 10:25 AM
Flatlinedan
Sep 18, 2015 12:41 PM
S3an
13
Sep 13, 2015 10:01 AM
