Escort Cosworth 450BHP Engine And Ancillaries
Escort Cosworth 450BHP Engine And Ancillaries,
Small turbo engine, Pocketed pistons standard ratio, 6 long studs with 4-layer head gasket, ARP Conrod and flywheel bolts, Ported head (26mm Inlet, 24mm Exhaust) Small turbo inlet manifold, Billet fuel rail, 83lb injectors, bd14 inlet cam, Double valve springs, 2wd exhaust manifold, CR turbos rollerbearing t38, Baileys Oil breather, 2wd Big wing baffled sump, 6 paddle clutch, Coil pack conversion, twin Amps, P8 Ecu, 2wd flywheel, 3 Bar Map Sonsor, Engine Loom.
In grerat working order covered 9k since being rebuilt.
P.O.A
P.O.A
