Various parts, intercooler, t25 turbo
Old Jul 27, 2013 | 09:03 AM
cossie col's Avatar
cossie col
Default Various parts, intercooler, t25 turbo
All parts are plus post or ideally can take to ford fair or Combe Rally car day or you can come and collect and have a cuppa
Original big turbo inter cooler with charge cooler bit. Has a small dent on rear but this is how it was when I bought it and there was no leaks etc so I will guarantee it
Lookin for £80plus post
Charge cooler kit for big turbo inter cooler with charge cooler. Was in my unit and one of the lads that works for me put it in the scrap pile so as you can see its a bit damaged as in fins want straightening and has a slight dent but don't think it leaks but this is free any way as its the pump, controller, expansion tank and few bits of pipe I'm selling for £60
-31 actuator and a very good adjuster as you don't spin the actuator rod or have to take pin off wate gate to adjust, done about a 1000 miles on my old rb t4
£50
Seat runner covers
£50
Painted small turbo inlet £140
Old Jul 27, 2013 | 09:06 AM
cossie col's Avatar
cossie col
This is the original t25 off my car which was removed at 28k so not done to many miles
Lookin for £300 plus post or you can collect or pick up from ford fair or Combe Rally Day
Before I forget its got the dump valve bypass kit in it so this is ideal if you want to fit an external dump valve or just remove and fit your standard dump valve in it
SmudgerByName
52
Jul 28, 2016 06:14 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Marcus L
Aug 29, 2015 02:18 PM
IAN RS2k
Aug 18, 2015 07:51 PM
