Radtech intercooler for escos aircon model
As above Radtech inter cooler for air con model which allows you to keep your air on rad which sits in front on the brackets. I have 2 bosses welded on inlet side and these are tapped for water injection nozzles but I have popped some blanking bolts in. Not sure if you can use with a normal rad and fans but I am still using the rad that came with kit so that is not for sale. It is in good condition and just needs a clean or painting black
Looking for £200 plus post but would rather you picked up or I can take to ford fair or Combe rally day
wowk
Mar 30, 2021 07:49 PM
