Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
fan running
Old Jul 24, 2013 | 02:04 PM
niri99's Avatar
niri99
Default fan running
Hi
i got focus tdci 1.8 diesel 2006, fan run all the time when engine is running
even in cold need help to sort the problem.
Old Jul 24, 2013 | 03:11 PM
st220kyle's Avatar
st220kyle
are you sure its not because you have your air con on?
Old Jul 24, 2013 | 04:33 PM
uruk hai's Avatar
uruk hai
If you have the blower on windscreen only the air con will be on and that will cause the fan to run. On mine when you have it on windscreen only the air con is on but not the air con light !
Old Jul 25, 2013 | 07:04 AM
niri99's Avatar
niri99
Default fan
air con is off and blower is not on windscreen
where is cooler temperature sensor located.
simonmcf
Sep 22, 2015 08:40 AM
21
Sep 14, 2015 06:38 PM
Vacuman
Sep 11, 2015 11:37 PM
Adam Graham
Sep 6, 2015 06:04 AM
