bringing a cosworth back to life!
hi and thanks for looking at my thread. I have just purchased a saph cossie 4x4. the story with the car is it has been stood for over 5 years. I am basically after a bit of advice. before getting her on the roads I want to fully service the car, engine oil, plugs, leads, g'box oil, diff oils, transferbox oil etc. I'm basically after advice on what grade oils I need for the car.
engine oil?
g'box oil?
diff oil?
transfer box oil?
thanks for looking and any help that can be given. cheers
engine oil?
g'box oil?
diff oil?
transfer box oil?
Engine oil will differ with opinion, but I use Mobil 1 10W60. Fairly cheap too from Matt Lewis. My mate put it in his 4x4 saph and it quietened it down and stopped a slight oil leak he had.
Plugs I use the Motorcraft 071's. Again from Matt at around Ł10 a set.
Make sure you check all the brake and fuel lines for corrosion too, and it'll probably need some bushes after that time.
cheeRS
cheeRS
steerfromdarear
28
Jan 29, 2016 06:14 PM
Roosie
27
Aug 19, 2015 12:16 AM
Aug 14, 2015 07:29 AM
